FOUND! Rear View Mirror Risor for Toyota Frameless Homelink Mirror
marp
Dallas, TX
Acura, Honda
I installed a Toyota Frameless Homelink Mirror (PT374-00210) and it's great except that I can't raise the mirror as high as I'd like. On one of the many Mav FaceBook groups, someone mentioned they used a "toyota yaris mirror riser" and a quick google search showed me several options. I ended up buying one off of eBay for around $50 and installed it yesterday.
Glory be, it's exactly what I wanted! :D
I'm now able to raise the Toyota Homelink Mirror to max height and I have a better view across my windshield.
Pics attached in case this helps anyone else.
Thanks!
Ford Maverick FOUND! Rear View Mirror Risor for Toyota Frameless Homelink Mirror mav-mirror-adapter_6
Ford Maverick FOUND! Rear View Mirror Risor for Toyota Frameless Homelink Mirror mav-mirror-adapter_3
Ford Maverick FOUND! Rear View Mirror Risor for Toyota Frameless Homelink Mirror mav-mirror-adapter_1
Ford Maverick FOUND! Rear View Mirror Risor for Toyota Frameless Homelink Mirror mav-mirror-adapter_5
Ford Maverick FOUND! Rear View Mirror Risor for Toyota Frameless Homelink Mirror mav-mirror-adapter_4
Ford Maverick FOUND! Rear View Mirror Risor for Toyota Frameless Homelink Mirror mav-mirror-adapter_2
viperman
Pa
2025 Maverick Lariat, Azure Gray
Thanks!
What is the URL on ebay for the adapter? Also do you have to remove the cover to remove the mirror?
marp
marp
Dallas, TX
Acura, Honda
TNFurb
Kelly
Nashville
‘23 Bronco Sport OB ‘24 Mav Lariat Hybrid
Here's the one I purchased: https://www.ebay.com/itm/145222215831
I did not have to remove the cover when I swapped to the Toyota mirror or when I added the risor.
I hope this thread isn’t too old. So how did you hook up the power to the Toyota mirror when you swapped it out if you didn’t have to remove the cover in your Maverick?
TNFurb
Kelly
Nashville
NVM I found the mirror and I see it is battery operated for homelink so not auto dimming. I may consider this mirror too whenever I get my Maverick.
Mavtremor24
Tony
Ohio
2024 maverick tremor 2024 space ford explorer timberline 2000 black svt contour
Get a frame less from a 2018 mustang works great
Area51BS
Ron
Hardwired. Not battery. I’ve purchased 2. One for $10 and one for $20 from Kia. Same mount works on Maverick and I have the other on my Bronco.
