FORSCAN: Missing bodycm module
sethwatters
Seth
Marietta, GA
2023 Hybrid Lariat Lux
Hey all! Newbie here with a question.
I bought a Forscan ELM cable on Amazon. After a couple of hiccups, I was able to get it connected to my Mav using a laptop. The tweaks I want to make (global open/disable double honk) are apparently in the bodycm module, but that module is missing from the list of modules. Any ideas about what's going on here?
Thanks!!
Seth
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
Which modules are showing up? The Maverick has multiple CAN buses. More expensive OBD adapters can automatically switch between the different buses.
Ford Maverick FORSCAN: Missing bodycm module MavCAN.PNG
Montana
Did you update the firmware? It should prompt you on your first connection.
sethwatters
Seth
Marietta, GA
Here are a couple pics of the modules that are listed. I bought the cheaper option for the ELM cable, and I ordered the recommended one today. It will arrive tomorrow. Hoping that fixes the problem.
Ford Maverick FORSCAN: Missing bodycm module IMG_0361
Ford Maverick FORSCAN: Missing bodycm module IMG_0362
sethwatters
Seth
Marietta, GA
The firmware on the computer? I downloaded the most up to date version from FORSCAN...
Montana
You skipped a step or missed somethig. You are in the wrong menu.
Click the chip icon that is labeled "Configuration and programming" to access the correct menu.
Start at 5:00
Twixel Jackson
Charles
Ohio
2022 Ford Maverick XL
For what it is worth, when adding cruise control to my 2022 XL, the most recent version of Forscan did not have what I needed. I downloaded an older version and the modules I needed were there.
The adapters usually have their own drivers and firmware to download. FORScan can automatically update the firmware for some adapters like the vLinker.
Also when you go to rescan after getting your new cable or whatever delete the old truck profile it may have saved. Otherwise it may tend to only look for the known modules.
Automate
Start at 5:00
If FORScan can't find the module, there is no way it is going to program it.
sethwatters
Seth
Marietta, GA
Start at 5:00
It's the same list in the Chip tab. I only used that tab because it's like the list that Automate sent over.
sethwatters
Seth
Marietta, GA
I was wondering about this. I looked around today trying to find an old version and was unsuccessful. Do you remember where you found an older version?
Twixel Jackson
Charles
Ohio
I found it on the forscan website. I don't have my laptop available to check where exactly I got it on the site. But I know for sure I got it there. I can check tomorrow.
I know I downloaded Forscan in March and there was a new version from February 2023. I went back and found one from October 2022 and it had what I needed.
At the bottom of the main screen on Forscan, look for "Full FORScan v2 Changes History" near the bottom. It lists all the older versions you can Download. That is where I got the older version.
Hope this helps.
https://forscan.org/download.html
sethwatters
Seth
Marietta, GA
Hope this helps.
That’s great! Thanks for sending.
sethwatters
Seth
Marietta, GA
Gullzway
OK
1968 Ford Mustang Fastback
I use this one, $35, works great!
Vgate vLinker FS OBD2 USB Adapter for for-Scan HS/MS-CAN Auto Switch https://a.co/d/53wFInB
