Ford to launch Maverick EV (I hope this is true)
dalola
Retired
SE Ohio 🇺🇸
oh boy, I have multiple dedicated 20amp outlets in my garage, box on their own breakers, right onto of each other. I can pull one of them, and turn that slot into a 240v 20amp box, and need to change the outlet of course too.
but that means I can have 20amp 240v charging for literally minimal effort. I had 3 dedicated 20amp outlets ran a few years ago, 1 for treadmill, one for a deep freezer, and one for power tools, they said it would be cheaper to run multiples instead of one, so I paid like two hundred extra for 3 of them.
I kind of want a PHEV or EV now knowing that I can charge at fast speeds
I did something similar when we got our Mach-E. I had a 20A 240V outlet in my garage for an air compressor I no longer had, so I put our Emporia smart charger on this circuit, and dialed it down to 16A continuous charge (80% load), we get about 15 miles of range per hour, which works fine for us, as my wife's commute is generally in the ~60 mi/day range. If you don't need to charge at higher amperage, a set up like this works just fine, and is potentially safer, and easier on the HVB. Just FYI... 🤠
North Coast Joe
NW Ohio
2024 Ford Maverick XLT Hybrid. 2022 Honda CR-V EX-L
Ford lost $5 billion in 2023 and another $5 billion in 2024. Much of that on EV'S and similar crap.
I hope they are wiser than to do that again. The EV quota was just cancelled anyhow.
The Real Maverick
Jack
That's totally a good option for you.
240 VAC x 20 amps = 4.8 kW.
Assume 4.5 kW makes it into your battery. That will mean you can charge about 20 miles of power per hour on the plug summer, and about 15 miles per hour winter.
Assuming most folks are home 12 hours a day, that's 240 miles per night you can recharge with minimal equipment.
FreedomPenguin
Dayton
id honestly go full EV at that point, let my gf use her nissan rogue as our far away commuter for trips and such. it would seem that it is making more and more sense to sit back and wait for a full refresh maverick, as I still have a reliable DD.
after investing all these hours on the forum, its making me really consider waiting. I was reading and YouTubing, there seems to be a lot of speculation for a full EV coming out in 2028.
dalola
Retired
SE Ohio 🇺🇸
You can't pull continuous amps at full rating, it has to be no more than 80%, which is 16A max continuous on a 20A circuit. That will net ~15 mi/hr recovery to the HVB. (look at post #151)
WileeCoyo
Pacific Northwest
1994 Ford Ranger
I am truly amazed at how many people won't give up their horse for a horseless carriage. Personally, I would love to move to all electric. No oil changes or gas to deal with. I try to stay away from the items that can blow up.
Phimosis
Larry
Santa Clarita, CA
I too, have an $400 Emporia charger, but I had an electrician install a NEMA 14-50 plug in, with a 50 amp breaker and the appropriate sized wiring, for $600. Then it’s 3 screws to mount the wall charger next to your outlet plug.
Ford Maverick Ford to launch Maverick EV (I hope this is true) IMG_2003
In this configuration, it can supply 40 amps, or 9,600 watts at 240 volts. According to National Electrical Code rules, a 14-50 plug, 50 amp breaker and appropriately sized wiring can operate at 50 amps “intermittent”, which in NEC terms means “loads expected to last less than 3 hours”. Since EV loads frequently go longer than 3 hours, they are considered to be “continuous” loads and are restricted to 80% of their maximum rating, out of the box. However, the Emporia charger is rated for 50 amps continuous, which means that if you have it hard wired to a 60 amp breaker and larger wiring, it will operate at the 80% duty cycle, 48 amps, or 11,500 watts continuous.
When it comes to efficiency, you have about 5% thermal loss in the car onboard charger, where the AC to DC rectification happens. And you have about 5% thermal loss in the battery while it charges.
Side note: the EVSE, electrical vehicle supply unit, or Emporia wall unit, it’s just a fancy, web connected power switch and just passes current through with negligible thermal loss.
My daily electrical use in winter, according to my trip computer, is about 33 kwh per day. My Emporia charging logs shows that it sent 37 kwh to my car, so 10.8% thermal loss, meaning the power company is charging me 10.8% more than what my car says that I added.
Ford Maverick Ford to launch Maverick EV (I hope this is true) IMG_2005
So 4 hours of charging at 9,600 watts.
My commute is all freeway at 80 mph, so my consumption is 350 watt hours per mile. When you see manufactures talk about miles of range added per hour, they are going to be using the city EPA consumption, which will be around 250 watt hours per mile, in order to make the charging rate look more palatable. But for freeway only, expect 320 to 350 wH/mile.
Ford Maverick Ford to launch Maverick EV (I hope this is true) IMG_2004
But I don’t actually have to pay for this electrical use, because I make 21,100 kWh (21.1 MWh) per year.
Ford Maverick Ford to launch Maverick EV (I hope this is true) IMG_2006
Even in early Feb, I’m making 52 kwh on sunny days. Last week we had a storm and it went as low as 20 kwh with dense cloud cover.
Ford Maverick Ford to launch Maverick EV (I hope this is true) IMG_2007
As mentioned in an earlier post in this thread, I have a 14.4 kw Tesla system from Tesla.com/energy, 36 panels x 400 watts. It was $33,600, which was $23,520 after the 30% tax credit for solar installations.
Even in early Feb, I’m making 52 kwh on sunny days. Last week we had a storm and it went at low as 20 kwh with dense cloud cover.
Do you have the Power Bank?
Phimosis
Larry
Santa Clarita, CA
No, I didn’t buy the Tesla “power wall” battery backup. Each one holds 14 kWh of electricity. The first one costs $12,000 and each one after that is $7,000. I would need at minimum, 2 power walls and probably 3 of them to run my house comfortably, so $19,000-$26,000. The first one is more expensive because it includes the intverter, wiring, city permit and inspection.
I have had solar for 2.5 years and I have had zero power outages. My thought going in was that if power outages became an issue, I could get a battery backup installed later. So far it is not looking like I need it.
inline_five
2023 Hybrid XLT
I know you're trying to be helpful, but you live in an area of the country that gets rain 1.8 days a month. You also live in an area that pays out the wazoo for electricity at ~$0.40/kwh (I choked just writing that!!).
Most of us live in much more varied climates with many more days of cloudy, rainy weather and pay 1/3 of what you do in electricity.
If I lived where you do I'd 100% before solar.
Maverick Man
Larry
Bonney Lake, WA
2013 Mazda 3
Let's see if the tax credit is around still. If you can snag the hybrid for 30k and they sell the full electric model for 40k after tax incentives, I don't spend anything remotely close to 10k in gas/maintenance so for most consumers it would make zero sense.
I don't want my taxes going for those who can afford an electric vehicle. Seeing that Ford is losing so much on electric vehicles already, it's hard to see how this is a profitable idea, though I admit, it sounds good.
The Real Maverick
Jack
I hope you know, the exact form of Hybrid you are driving now received subsidies for about the first 10 years or so. It takes a while for prices to come down to Par. But the Maverick is an example of hybrids now being on par with gas only vehicles.
WileeCoyo
Pacific Northwest
1994 Ford Ranger
I LOVE it when someone shows their homework! Planning on getting a new roof next year and adding solar! You will never see so much information from me! Thank you!
Scott Asheville
Scott
Asheville, NC
I made sure my electrician wired a high amperage 240V outlet in the garage while building my house. It was cheap future-proofing.
Scott Asheville
Scott
Asheville, NC
One thing a lot of well-intentioned ICE folk on MTC miss is that Ford competes in a global market. The US market right now is around 17 million units a year. The global market is almost 90 million units. Volume is everything in the global market - if you don't have scale, you become a small boutique maker like Ferrari. That doesn't mean you don't make good money. It just means you sell to a niche. You're small and irrelevant.
The market in the developed world is going BEV in a big way. If Ford and the other USA OEMs don't move to BEVs, they become uncompetitive on the global market because they will lack the scale needed to compete.
You have to spend money to make money. You can call it a "loss" all you want, but it's an investment in the future. Ford "lost" $1.5 billion developing the Maverick. And it takes years of sales to recoup that R&D investment - they're probably just starting to make real money on a program basis now. But once you recover your investment costs, then you're printing gobs of money.
So Ford, please keep "losing" $5 billion a year on BEVs. Because I want to be able to buy a Ford in 2035, not a BYD.
