Ford Escape rear coil springs on a Ford Mav
Gary L
Green Bay, wi
2024 Ford Maverick Lariat with 4K Tow
I am wondering if anyone has done this?
I really like my 2024 Mav Lariat AWD, but the ride seems so harsh on my bad back, primarily when the rear wheels hit a bump. I've already switched to 17" wheel for more tire side wall, I'm running only 32 PSI in the rear tires, I tried weight in the back, I even modified some KYB adjustable shock for the rear, which did help some, but still not enough. So I think the rear coils springs are just very stiff for such a light truck.
Supposedly, the 4th generation Ford Escape and the Ford Mav use the same Ford C2 unibody platform architecture. The spring rate on the Mav is 338lbs/in. The spring rate on the Escape is lower for a softer ride, but I can't find the actual spring rate.
So anyhow, from what I've read, the Escape rear spring should be close enough to fit and I'm wondering if any has done this or has the part number for a 2024 Ford Escape AWD rear coil spring.
Thanks
El Kabong
Carnation, WA
I think it will make the handling squirrely if you soften the back up, not to mention you will lose load capacity. Rear springs are stiffer because it's a trucklet and is supposed to carry a load.
I've not seen anyone that has modded the truck for a softer ride in all my readings - I think you are pioneering the effort.
Have you looked into having the seat cushioning customised? Maye the seats from a Lincoln would be better?
Gary L
Green Bay, wi
I kind of figured nobody has probably tried this. Most want their truck lifted or lowered, not softened up.
I did try putting a seat cushion my wife bought me but I lost too much head room.
And you are probably correct that with a lower spring rate in the back it may get squirrely. I do see where the front spring rate is only 148lbs/in. I can't seem to find the spring rates for the AWD Escape with the 2.0. If it was a little lower, like 300 lbs/in for the rears, if figure it might help and still be safe driving. But hard to predict.
Cancunbadlands
Cancun
Cancun
You might need to find the actual Escape spring rate.
Tailender
Will
Poconos
1995 F-250, 2011 Rogue, 2012 Jeep Liberty
I thought someone said the Tremmor struts in front made the ride softer? Not sure about the rear though.
Quest
Tires are the greatest point of absorption.
On my old Freester I had 17" summers & 16" snow tires.
The 16" were a lot softer ride than the 17"
Don't know if there are 16's available for Maverick
commadorebob
The smoothest ride I've ever taken was in a modern-ish Ram 1500 with air suspension. The smoothest Ford was in an Expedition with active suspension. What those two have in common beyond a fancier suspension is weight. Given the Maverick's small size and light weight, it might be harder to find something you can bolt on without completely overhauling the entire system, and then it becomes a cost-benefit analysis.
Gary L
Green Bay, wi
Thanks ScottyC
Interesting post. I'll have to look it over better when I get a chance.
Mabcim
Rochester, NY
Gary L
Green Bay, wi
