For anyone that put Escape wheels on your Maverick, please READ
klutch14u
2025 Maverick XL
How did you deal with the wheels being designed for M12 lugs and having M14 studs? If you just used M14 lugs, did they seat properly?
CTYankee
Central MA
2022 Maverick XLT
12mm or 14mm is just the thread pitch of the studs. The head of the nut doesn't matter as long as it's the same type of seat as the wheel (acorn, etc.).
Hot Runr Guy
West Chicago, IL
I had the same issue with Bronco Sport wheels (which also use 12mm studs). The BS wheels fit over the 14mm studs just fine, the taper is the same, I only lost about 3/4 of a turn of lug nut engagement.
HRG
LSchicago
Lloyd
IL
Zero issues from the size difference. The taper is the same.
Tiger Dude
Skip
Louisiana USA
2023 XL
I'm not saying there is/is not an issue with using the M14 lugs on a wheel designed for M12, but the difference in M12 and M14 is thread spacing and bolt diameter (the 12/14 is the diameter in mm).
Seating properly could be an issue even if taper is the same. Does the m14 properly bottom? The main concern, I believe, if the wheels designed for the M12 have the load capacity at least as much as the wheels designed for the maverick? (Will you have to give up some of your "GVWR" allowance?)
AzureBlueBill
Torrington, Connecticut
A 14 mm bolt/stud is 2 mm larger than a 12 mm bolt/stud. M12-1.5 means 12 mm outside dia. with each full thread being 1.5mm wide. M14-1.5 means 14 mm OD with each full thread being 1.5mm wide. "1.5" is the pitch of the thread, and there are also M12-1.75 threads and 14-2.0 threads used on some lug nuts. None of this has any bearing on what wheels work with what nuts. All you need to do is make sure you use 30° taper nuts on wheels with 30° taper lug holes. As long as the studs fit thru the holes in the wheels, you will have no problems. And I have NEVER encountered a wheel where the lug holes were too small. Although I suppose there are some oddball situations out there.
AzureBlueBill
30° is 30°. They seat just fine. Nobody designs wheels for only one stud size. Go shopping for aftermarket wheels. You will see. For example, most wheels that fit a Ford Fusion also fit a Maverick. There is no difference in the wheels or wheel part numbers. Most Fusions had 12 mm studs, most (all?) Maverics have 14 mm studs. It does not matter.
Yes you should check load capacity of the wheels, and tires. But given the lightweight nature of the Maverick, I don't think you'll ever overload any decent wheel or tire.
AzureBlueBill
12 or 14 mm is the diameter of the studs. The pitch is the width of one revolution of threads. That's why when buting nuts or bolts you'll see numbers like "14-1.5". Which is 14 mm diameter with a 1.5 pitch. Imperial sizes are similar, except you'll see numbers like "1/2-20" which is 1/2" diameter with 20 threads per inch.
The reason mavericks have 14 mm studs and not 12's is a lot of them have significantly less load limits. It's just a cover in case someone doesn't check load limits.
