Fog light kit for Maverick?
hsinking1932
MA
Explorer
I have a question. If I go to install aftermarket fog lights, where will they put the switch? I wouldn't say I like drilling holes in the dashboard. Maybe a bluetooth switch glued by a 3M tape?
The lower dash piece the USB ports and 12V outlet (and rear window/push button start on Lariat) are on probably wouldn't be a bad place if you're going to drill. Shouldn't be expensive to replace if you need to return to stock.
oljackfrost
Minnesota
Below the light switches is a big blank panel just itching for a fog light switch!
Ford Maverick Fog light kit for Maverick? 12991A9C-15C6-42B9-8C26-F4B7A0C3BC13
hsinking1932
MA
Explorer
@Darnon @oljackfrost
Thank you for point the perfect place. I never drilled my cars before. Maybe Mav is a good start. My town hired some hunters to reduce the number of deers last winter, but it didn't work well...
bpcooper14
'08 Nissan Frontier
That opening next to the entertainment system is begging for a 6 or 8 gang switch to add all sorts of extras (bed lighting, fog lighting, interior ambient lighting, etc.)
A Dodge that drives Fords
Wisconsin
Ford Taurus Ford Ranger
I second that
r100gs91
The center of the USA
Kinda disappointed that there are no Fog Lights available. My current 2018 F-150 has marvelous fog lights. They do a a damn proper job of illuminating the sides of 2 lane country roads and non lighted interstate type entrance ramps. I'm spoiled.
r100gs91
Then where will I put my Dancing Hula girl :unsure:
Delzona
Tucson, AZ
I believe that's where the tow brake boost switch is placed if you have that optioned on your Mav
lbk3b4
Jean
maine
Ford
I live near the ocean and fog lights really help when the advection fog rolls in off of the ocean. Been wondering where to mount fog lights. Any thoughts?
mamboman777
Josh
NRH, TX
You could put it next to the screen in the weird cubby!
Evil2ltr
Kevin
Asheville, NC
2022 Alto Blue Maverick XLT AWD
Need them here in WNC.
Willis
Belleview Florida
2015 Ford F-150
Actually the Mavericks have 3 built in fog lights in the headlight assembly:
Four trim levels are available for the 2022 Ford Maverick: the XL, XLT, Lariat, and Lariat First Edition. ... The Maverick has unique headlights, including the normal headlight lamp, a daytime running light lamp, and three fog lamps in the same unit
Willis
Belleview Florida
2015 Ford F-150
It’s like the previous generations of the F-150 Raptors , none had factory optional fog lights , but the new 2021 Gen 3 now has optional or factory standard fog lights
