TacoTanium
Earth
XLT
OP, great thread!
The PTU needs to keep it's limited slip for the clutch, does the RD needs this kind of slip as well or is it all metal contact?
Sjurgen
Shannon
Oregon
Chevy Spark, Toyota Prius, 1973 F100
I’m not sure. I believe the PTU is on/off and the rdu is slip.
dalola
Retired
SE Ohio 🇺🇸
Regular AWD Mav's (non-Tremor), the PTU is always engaged, and the drive clutch (disconnect) is in the RDU.
TacoTanium
Earth
XLT
Interesting article and how he mentioned the PTU is not enaged all the time......." driveshaft and gear sets that it’s attached to stop spinning". I find that pretty hard to believe that it engages while the driver doesn't feel it..... When "driveshaft and gears" are not spinning and then it all of a sudden spins to match the speed of the gear to be engaged, you'd think there would be a big thud/gear sound. Pretty cool they can make it silent or not enough for the driver to even hear or feel it.
  • Like
Reactions: bgn
Nw_adventure
Salt Lake city
So looking into the PTU/RDU fluid change- Do they use the same fluid XY-75W85-QL ? Seems there is some debate on the RDU using a straight 75W- Thx
dalola
Retired
SE Ohio 🇺🇸
No debate, they are different oils (and part no's) & different weights....the RDU is indeed straight 75w.
Nw_adventure
Salt Lake city
OK and there we have it- Now need to order SAE 75W - Ok to reuse drain plugs ?
dalola
Retired
SE Ohio 🇺🇸
Yep. I use just a dab of liquid gasket to insure a good seal without over-tightening.
(PS> I found Rock Auto to be the cheapest source for the OEM Motorcraft oil)
Nw_adventure
Salt Lake city
Thx - Saw that as well.
Nw_adventure
Salt Lake city
The RDU takes 1.4 Quarts for a D/R ? Was hoping to only have a single quart to buy- Thx
dalola
Retired
SE Ohio 🇺🇸
No, both should be about half quart each. Very small capacities, thus the advantage of changing more often.
Nw_adventure
Salt Lake city
Isn't the ptu fluid 75w85 ?
Correct. Doing my fluid swap today. Will be interesting to see what the fill level and condition of the oil is at 16K miles - RDU will be next week.
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
I did my rdu and had some clutch material there. But nothing mayor. I did it at 26k and i track thos truck before. Im kind of worried about my ptu because i did have a overheat code before.. 😅
