- Banned
- #76
I hope a forum member does this but with the back leveled so we can see a write up with some details.. The front I think is a perfect height so that is done. That would be sweet!! Should be doable under 400 I am guessing.
The Maverick in stock trim with 30.5" tailgate height is exactly perfect for me so I don't have to use our F-150 for most of my truck needs/adventures. I am going with steelies too, and that keeps it exactly the right height I was looking for to suit my short legs and cranky backIf you use the right components it can increase the payload and ride quality. The truck highlighted in this thread is not that version. I love the look of lowered vehicles, but I bought this truck to get better around in the winter so I probably wont mess with it.
Wouldn’t the SEMA maverick be the first lowered?Someone Lowered a 2022 Ford Maverick Already and It Looks Sick
It's time to embrace slammed mini trucks again.
From: https://www.thedrive.com/news/42904/someone-lowered-a-2022-ford-maverick-already-and-it-looks-sick
October 28, 2021
Judging by the 100,000+ reservations for the new 2022 Ford Maverick, it'd be an understatement to call it well-received in the United States. The truck that's capable of 42 miles per gallon in the city brings the small pickup back into the limelight without sacrificing utility, and with a price tag of just over $20,000, it was only a matter of time before enthusiasts got their hands on one.
That's where Adam Edwards comes in. He's the owner Tedder's Body Shop in Searcy, Arkansas, and it didn't take long for him to become one of the first with a modded Maverick. Within a few days of taking delivery, he found a way to lower it.
Since no company officially makes an aftermarket lowering kit for the Maverick (yet), Edwards had to improvise. He took some measurements of the Maverick strut assembly and went to an auto parts store. After comparing a few options, he left with a pair of struts meant for a sixth-generation Nissan Sentra.
Edwards said that the strut mounted right up after replacing the top mounting cap with the factory Maverick part, and the only modification needed was a small 3/8-inch slotting on the bottom bolt hole.
The rears were a little more complicated. Edwards found a set of rear shocks meant for a number of older Fords ('66 Bronco and late '70s F-Series pickups) that also fit on the Maverick. Then, he cut down the rear springs and replaced the lower spring insulators.
The overall result was a four-inch drop in the front and a six-inch in the rear. In hindsight, Edwards says he wishes he had leveled it out just a bit more by only lowering it five inches in the rear.
This setup is just temporary, though. Edwards' Maverick will be headed to SEMA 2022, complete in mini truck attire. He tells us that he plans to put the truck on air suspension and that his build process will begin sometime in the next week or two. At least he gets to have some fun with a lowered truck on steelies in the interim.
Edwards told The Drive he hopes his project will inspire people to build next-gen mini trucks, and maybe even bring mini truck culture back to its former glory. Before compact pickups stopped being built, the hobby was thriving in all parts of the country. With the introduction of the Ford Maverick and Hyundai Santa Cruz, perhaps we'll see that scene make a comeback sooner than later.
"I believe if the people don’t embrace what we’ve been given here, we might never see a mini truck again," said Edwards. "I’m hoping [that] people adopt these and build them [until] they are as played out as S10s were."
I have the 245/45/20 on a 20x10 wheel and they ride perfectlyHe has AWD doesn't he? Just wondering cause the FWD rear shock looks like its going to be the offset decider for me.
If you have the AWD the 20x8.5 at 40 offset will suit you well. It will have 4mm more clearance from shocks then the 275/40/20 and stick out 8mm less. Plus the 245/45/20 tires are the best value 20" tires which is also the stock diameter.
SEMA is this week. This would be the first shown to the world. I'm hoping somebody will offer coilovers.Wo
FYI escape/bronco kit sports will not work as the passenger side spring is left hand wound on the mavericks for somee reason. You would have to buy the driver side isolators and then might work.H&R makes lowering springs for the 4th gen Escape which should work with Mavericks and Broncos Sports(although I think that lowering a Bronco Sport is the wrong direction for that vehicle). They can be purchased through TireRack and shipped to you or the shop you want to have install the springs.
The drop is only 1.4 inches.
This dropped Mav is sick and it looks like more than 1.4 inches.
We should have PT springs in a few weeks here for the FWD models. Targeting 2" front drop and 3.5" rear drop for level lowering.I hope a forum member does this but with the back leveled so we can see a write up with some details.. The front I think is a perfect height so that is done. That would be sweet!! Should be doable under 400 I am guessing.
Do you work for Eibach? It's not a terribly far drive for me. I have a hybrid on order, but will happily come pick them up whenever if will call is an option.We should have PT springs in a few weeks here for the FWD models. Targeting 2" front drop and 3.5" rear drop for level lowering.
Check out Eibach's insta for updates.
https://www.instagram.com/eibach_world/?hl=en
Yea I work in R&D at Eibach, my guess would be production springs will hit the shelf summerish of 2022 given the current supply chain.Do you work for Eibach? It's not a terribly far drive for me. I have a hybrid on order, but will happily come pick them up whenever if will call is an option.
You can order online and pick up at will call.
They do have truck racingNot my thing. To me trucks and jeeps are to be lifted. Sports cars are to be lowered.
