Failed Struts - Mixed Experience with Ford - Big Shoutout to SAMES Ford
Reece @ DI
Reece
McAllen Texas
2022 Ford Maverick XLT Hybrid
I wanted to share my recent experience in case it helps anyone else dealing with warranty issues. Before my bumper to bumper warranty expired, I had quite a bit of work done (2022 XLT LUX Hybrid):
  • Both CV axles replaced
  • Brake pads and rotors replaced due to excessive noise (one pad was cracked)
  • 12V battery replaced
  • Suspension checked for a thump/rattle when hitting bumps while turning
At the time, the suspension concern was looked at, but nothing definitive was found. Fast forward ... my warranty expired by time (not mileage, currently at ~33k), and I had since moved to a new state. The thump/rattle progressively got worse, so I brought it to a new dealer. After diagnosis, they found the issue: failed struts that needed replacement.
The dealer recommended I contact Ford for possible financial assistance. I reached out and was initially told I was eligible for help as long as the issue was something that would have been covered under the bumper to bumper. After getting everything diagnosed and submitted, things went downhill fast.
My claim was closed with Ford without warning and I was told I was no longer eligible for any assistance. The explanation was that struts are considered a wear item, and I was out of luck. My first two calls with Ford were great, but the next two (after diagnosis) were the complete opposite. The reps I spoke with were dismissive and honestly pretty rude. They told me that what was shared with me on the first few calls was not correct and I "should have never been told that". This was especially frustrating and the only reason I bought it into the dealer was that there was going to be some sort of help with the repair. Otherwise I would have went to a local shop that does great work, at a much lower rate. My dad worked for Ford for 40 years, and my family has always been loyal to the brand. I made sure to express that, but it didn’t seem to make a difference.
Now for the positive part...
The service advisor, Beatriz, at SAMES Ford in the RGV completely turned this experience around. She went out of her way to advocate for me and personally contacted Ford to push the case further. Thanks to her, Ford ultimately agreed to cover 70% of the repair.
I know we are quick to call out bad dealer experiences and 100% we should, but I also think it is just as important to highlight the good ones. If you are in the RGV and need a solid service advisor, I highly recommend Beatriz at SAMES Ford.
Joe Strummer
Squamish, BC
2024 Ford Maverick XLT Tremor
How can anything be a "wear item" at only 33,000 miles other than things like brake pads, tyres, etc?
Reece @ DI
Reece @ DI
Reece
McAllen Texas
Exactly ... its a failed part (manufacturing or assembly) and this should not have gone out at 33k. Also, it was showing signs of failing earlier ... Just a disappointing experience with Ford all around, but not from the dealer, which is surprising.
TheRef
Bruce
Auburn, AL
Makes me feel glad I bought an extended warranty.
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
Well, shocks and struts (and related strut bearing plates) are a wear item, although, 33K miles seems a bit of an early demise...glad you got Ford to cover most of the cost.
Beau
MD
2022 Maverick XLT, 2011 Mustang V6 Convertible
What is the expected life of struts in a Maverick?
notfast
Los Angeles CA
Shocks and struts on any car that is not driven down a washboard road on the daily should last at least 50k miles, probably closer to 100k.
I changed out the shocks on my current car at 90k miles and they were just as good as the brand new ones.
Blew out a shock after one pass of Barstow Main (off road) on my previous truck with about 30k miles, but I don't fault the shocks. It had twin tubes and I was going at a decent clip, so I'm pretty sure the oil was close to boiling. Replaced them with monotubes.
