Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight
edmc
Ted
Ohio
2026 Ford Maverick Lariat, 2020 Subaru WRX STI
you'll see the taper engagement is much less on the BS wheels.
Yea I would agree with you. Picked these up to eventually be put on a Bronco Sport. Ran them on the Mav for a few weeks to make sure the wheels were okay prior to taking them to get new tires mounted.
The holes were noticeably smaller, and it seemed a bit sketch losing that much engagement surface compared to all the other stock Mav wheels I have tinkered with.
People do it though* and I haven't seen any bad outcomes yet.
Ford Maverick Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight IMG_5690
Hot Runr Guy
West Chicago, IL
People do it through and I haven't seen any bad outcomes yet.
Those are a good looking wheel though!
HRG
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Needs trim rings and some kind of centre cap.
edmc
Ted
Ohio
Here they are switched over. You can kind of see how the smaller lug nuts sit in more.
To me, it killed the idea of shopping Bronco Sport wheels for the Mav.
Ford Maverick Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight IMG_0495
Ford Maverick Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight IMG_0500
