WestCoastDriver
So. Calif.
2025 Maverick Hybrid
TL/DR: Used OBD2 port hardware + Android software + inexpensive Android device to create an auxiliary dashboard instrument gauge.
I’m a new 2025 Maverick XLT hybrid owner. I was looking for a way to monitor a few vehicle data points not generally or quickly available. Some were items I wanted to monitor real-time and observe change, others to observe what constitutes a normal number.
I particularly wanted to keep an eye on the 12 volt battery level and state of charge, and ditto for the high voltage battery. Also wanted to watch the engine/coolant temperature, and although there’s no practical reason to, I wanted to view RPMs and get a precise fuel gallons remaining readout. Also wanted a quick-to-get-to tire pressure readout.
After pounding the digital pavement, I went with Car Scanner OBD2 software on my Android phone, and Car2LS ScanX to plug into the truck’s OBD2 port. I enjoyed setting up the software, as it’s graphical and highly configurable, looks good and is easy to read. Android Auto (on the truck) recognizes Car Scanner OBD2 software, and I thought it would be excellent to have the software’s graphical display on the big 13” screen.
I was pretty disappointed to find that, while Android Auto did indeed run the Scanner software, the actual readout on the big screen was absurdly dumbed-down. Instead of the outstanding graphical readout, it was a simple, single column of numbers smashed to the left side of the truck’s screen. That was it.
I was gobsmacked. A little research revealed this to be a feature, not a bug. Apparently, for safety and driver distraction reasons, Android Auto imposes strict UI and functionality limitations on third-party apps, which are not allowed to display complex graphics. The interface must be simple, text-based, and "easy to read at a glance." This is painfully ironic for at least a couple of reasons: first, the readout type was so vanilla and so small that I had to strain to see the data I wanted to understand. That translates into too much eyes-off-the-road time. Second, it’s obvious to anyone who has spent more than 5 seconds staring at Google Maps in their truck that it’s graphically complex in the most significant and profound way. Everyone must follow the rules except Google.
I wanted the clean readout. My solution was to get a carrier-locked phone at Walmart and use it as an Android-only device that sits on my dash. I got a Tracfone Blu View 5 Pro. Only $30, but not a piece of junk. The device has a 6.75-inch HD+ IPS LCD display with a resolution of 720 x 1600 pixels and a 20:9 aspect ratio. It looks great, and in combination with an Aonkey phone holder (which doesn’t damage the dash), it made a very effective second gauge display. Battery lasts a long time; I charge it up about once a week.
Gotta be sure to disconnect the software from the truck at end of trip to avoid a parasitic drain on the 12v.
Ford Maverick Extra Dashboard Instrument Gauge Installed SecondaryGauge
It works for me; as always YMMV.
I do similar with an old phone & Forscan Lite.
Gotta retry that OBD2 Scanner app - I thought when I tried it last, it had no profile for Maverick hybrid, had to select like Escape hybrid, and some values were wrong.
But that phone you got is much bigger and brighter.
FYI - there are probably lights on your OBD2 adapter, after you close the doors you'll easily confirm how long it stays on, no matter if your device is connected or not.
It'll be sitting there searching for a BT connection it knew about, until the power is cut to it.
You'll probably find that as soon as you move key to off (or push button for off) - the values stop updating, or phone complains there is no connection to truck already.
It'll keep BT connection to adapter, but the adapter is getting nothing from truck.
But you are probably saving the battery on the phone, because once adapter loses power than phone is looking for it.
dhaskit
Dann
2024 Maverick FX4 Lariat
Wow! That looks great.
Thanks for posting the info.
WestCoastDriver
WestCoastDriver
So. Calif.
• The Scanner app has Maverick profiles up to and including 2025. I bought the Pro Edition.
• Yes, the adapter does eventually power down; also it's an easy software-button push to disconnect the software from the adapter.
• The phone is an obvious loss-leader for Tracfone. At $30 it's a steal. The hardware is not the latest/greatest, but it's running only the scanner app and is plenty snappy.
I will confess: I'm a data dork. The truck is my toy and I sit on the flight deck.
Thanks for the notes!
Mabcim
Rochester, NY
Nice mod
AutobahnSHO
Will
S.Carolina
Maverick, Miata
LOL I have so many old phones in a drawer somewhere, I should use one for just the truck.
BlueMav43
Roger
NE FLA
2023 Ridgeline RTLE, 2018 Tahoe LS
This will tell you about your Hybrid voltages. CarScanner app on old iPh6 & OBDII dongle.
Ford Maverick Extra Dashboard Instrument Gauge Installed IMG_1812
HenryFord
2025 Maverick XL Hybrid FWD(ordered)
This looks like a cool project. Would love to be able to see additional data.
Wow - really puts the smaller screen in perspective when an old iPhone is that much bigger!
Hcopter
KS
Thanks for the write up, thinking of copying your setup,
Do you know if other OBDll dongles work with Car Scanner? The Car2LS ScanX shows as unavailable on Amazon, and I see others priced from $8 to $150.
BlueMav43
Roger
NE FLA
iph6 was a misstatement & has been corrected. It‘s an iPad.
This one is the iPh6.
Ford Maverick Extra Dashboard Instrument Gauge Installed IMG_1920
