- First Name
- kevin
- Oct 2, 2025
- BATH CO ,VA
- 2022 XL maverick
- Engine
- 2.0L EcoBoost
the most important thing to do to protect your engine( block heaters work great) is to disable the automatic engine shut off when at a stop a good gearhead can accomplish this with a laptop,i dont think i would even use the 0 weight,this engine stop feature gives your engine too many zero oil pressure starts GM has learned a hard lesson on the 0 weight oils and these zero oil pressure starts cant be that great on turbo bearings,check and see what Honda uses,their policies seem to work well on close tolerance engines.I am about to do my first oil change, and overthinking what to put in. Recommended is 5W-30 but an alternative is 0W-30 in cold climates like mine, where the temp can go below -20. The chart shows 0W-30 can be used in any temperature, I am wondering why it isn't the default recommended oil. I am suspecting it is to protect the turbo in hot operating conditions?
