Dual 12v batteries in parallel?
Maverick Life
Southeast
Toyota
Anyone done it?
Just curious if anyone has resorted to drastic measures yet to address battery issues.
skyhawk
Airplanes motorcycles cars SUVs
If you dont have room for one big one, two in parallel isn't a bad way to go. But if one goes bad, it will suck the life out of the other one.
So if you were going to install two, you might consider just keeping one on standby and have a way to cut over to it.
Unless you needed long unattended or uninterrupted battery run time with the engine off, or you had a current (amps) deficiency, a parallel arrangement doesn't buy you much except the ability to charge both.
But there are other ways to keep the standby topped off, a small trickle solar charger perhaps or even a smart dc-dc trickle charger powered by the main battery, that will cut off if the main (supply) voltage drops below a set threshold.
Just spitballing. But if you are worried about the bad cells we have heard of in some Ford batteries, then the worst thing to do is strap such a battery in parallel to what may be a defect free battery
jsus
2022 Ford Escape Hybrid AWD
If you’re going to have to make room to make it fit anyway, why not just go with one much larger 48H6 AGM battery like many Escape Hybrid owners have done, which by all accounts seems to clear up almost all issues pertaining to low 12V SoC?
2021 Escape manual even lists that battery for replacements although 2022 regressed to the tiny 99RT4.
Maverick Life
Maverick Life
Southeast
Toyota
Definitely good thoughts here. Probably the only good way to do it is two new batteries from the same production batch and toss the stock. Hoping I never need to consider it. I like the cut over approach better too.
Maverick Life
Maverick Life
Southeast
Toyota
This seems like a good idea. I'm curious why the manual specifies an AGM for the EB but not the hybrid though. I noticed that AutoZone says AGMs require specialized chargers - maybe that's why? I'd be a little concerned about installing one if the hybrid doesn't have the necessary equipment on board to keep it healthy.
Ford Maverick Dual 12v batteries in parallel? 1687893444569
Simply just a matter of changing the battery type in the programming. You can do it with FORScan.
bgn
WA
Interesting. Lots of 2022 Ecoboost units were not AGM. Mine wasn't and neither was the replacement.
jsus
Also, the hybrids have generally gotten an even smaller battery than the undersized 99RT4 the manual calls out for replacements. Why the inconsistency, I have no idea.
Maverick Life
Maverick Life
Southeast
Toyota
curiouser and curiouser
availability would be my guess.
in your earlier reply you mentioned using a larger battery in a hybrid. I don't have a hybrid but I've seen the battery box. can you really use a larger battery without cutting plastic or metal?
