Driver's Side Window Control
UTAlumnus
Robert
East Tennessee
2022 Velocity Blue Maverick
Anybody had the controls stop working? None of the windows will open from the driver's seat. I can reach over & work the passenger's side or rear driver's side from the switches on those doors but not from the master controls.
There have been problems in the past with drivers window control but usually it affected the passenger side rear window operation. The fact that the windows operate by their independent switches means that the fuses are all good.
I fear that your driver side window control has given up the ghost and needs to be replaced.
https://www.mavericktruckclub.com/forum/threads/passenger-rear-window-stuck-in-down-position.17150/
https://www.mavericktruckclub.com/f...e-rear-passenger-window-will-not-go-up.33446/
Owners have been reporting this on other forms.
Ford Maverick Driver's Side Window Control 20251017_094033
Assume a bad switch or fuse - just a guess.
Check your manual for fuse info
Fuse #6 10 Amp
Moonroof
DC inverter
Driver door switch pack
Power slide rear window switch
Fuse #6 10 Amp
Moonroof
DC inverter
Would it be a fuse, if the windows operate individually from their own door switches?
UTAlumnus
Robert
East Tennessee
I got lucky. They were all up at the time.
UTAlumnus
Robert
East Tennessee
Fuse #6 10 Amp
Moonroof
DC inverter
It's doubtful that fuse #6 blew. Rear window works.
No idea, just a guess. the manual shows one fuse for all windows (fuse #25), noticed fuse #6 showed "driver door switch pack", so I thought it might be power for that whole switch panel 🤷‍♂️
UTAlumnus
Robert
East Tennessee
I'll check it anyway.
billygoat
maryland
xl
Had that issue happen about 300 mi away from home base. Long story short, drove back on the highway with a garbage bag and a lot of duct tape. Ford found the problem was control fuse in the master switch and replaced it under warranty.
MaverickMark
2023 Maverick Lariat
I had that happen once about a year ago. Someone on here said to wait 30 minutes and try again. I did, and they worked. I haven't had the problem since.
UTAlumnus
Robert
East Tennessee
It fixed itself between lunch & going home that afternoon.
nhoffman1987
Buffalo, NY
2024 Maverick Lariat FX4 4K
This just happened to mine. I can’t operate my windows or adjust my mirrors from the driver seat. Passenger & rear windows still function using their individual switches. Fuse 6 & 25 were all good so it’s going in next week to get looked at.
