Pickles
Calvin
Kia rio, kia sorento
Hi all. Did the maiden tow on our work trailer. for reference, we use this trailer frequently to haul job boxes, welders, etc. 99% of the time we pull it with a F-250. Previously I’ve pulled it A few dozen times with a mid 2000s F-150. i have also used it once with a caravan (this was not an enjoyable experience) So those are the comparative reference points i’ll be using.
Quick overview:
trip was about 50 miles. 20 miles highway (empty trailer). 30 city (with just a welder and some scrap placed over the axles… so… lets say 2000-2500lbs total trailer weight).
Feel/towing confidence:
Super impressed with how the little thing handled the weight. Accelleration was suprisingly more than sufficient. visibility was fine. Would extended mirrors be helpful, sure, especially for backing up. But for occassional towing, stock was fine. Hitch height is also placed in a good spot for trailers this size. A small detractor, I hit a cross wind on an overpass with the trailer empty. This unsettled the truck a bit. Nothing unsafe. Just some jitters as the unibody tries to compensate for the sway.
drive modes:
Tow/haul feels really good. Shift points are where you want them. If you’re being light on the throttle for accelleration it kinda keeps you right around where your boost would start to kick in, so it attempts to keep your fuel econ in check, but gives you quick access to the power if needed. It fails in the prior lol but gracefully. I appreciated the attempt. The downshifting when coasting down a hill is very nice. Pretty perfectly set up for the rolling hills of the area i commute around.
Fuel econ:
as expected, it sucks. For reference i average 30mpg in normal driving. empty trailer on highway i got 17mpg. Loaded through city it fell to 13-14. It could be worse. But dont expect to save fuel by hauling a trailer with this thing instead of a full size truck lol
braking:
trailer brake controller works well. Ford didn’t try and re-invent the wheel. Its a familiar controller if you work with their ‘real truck’ sector of ford. Gain adjustable by the 0.5. standard is 5. I kept it at 6. I wanted a bit less strain on my mav brakes. Braking was confident, even when i misjudged a couple stop lights on the city portion. Despite being basically all city type driving for over an hour of driving there was no softening of brake feel. It felt the way it should. you feel the weight, but it doesn’t feel like its going to push you through the intersection.
overall thoughts:
ford gets a lot of hate in this forum… which is somewhat ironic, but anywho, one thing they do well, and the main reason i went with this instead of the santa cruz (aside from price and styling) is that ford knows how to set up a truck for towing. This has proven true even when its an Escape, Elcamino alien child. I was especially impressed by the lack of rear suspension sag. the size of trailer isn’t something i would suggest exceeding for any trip with overpasses, or windy fields. There just isnt enough substance to the back end to keep it grounded the way you’d want to haul anything bigger for long stretches with confidence. But overall, I Couldn’t be happier with this little baby truck. It can do so many big truck things… as long as you remember what it is at its core and dont expect too much from it too often.
Ford Maverick Double axle enclosed trailer first tow review 39D4121E-921C-4DAB-BED2-4A6FA5AB90BB
fossil
ernie
ohio
Great write up but that's "Escape, Ranchero alien child" to you bub. :ROFLMAO:
Jmav2152
Jamie
Cleveland, OH
Don't think I've heard anything so accurate in my life!
Great write up! I'll be hauling a Uhaul 5x8 about 1400 miles starting Monday with an estimated 22-2400lbs total weight. It's alot shorter than your trailer so shouldn't catch too much wind or drag super hard but I think the Mav will handle it fine.
commadorebob
Yep. I've been calling it an Escape Sport Truck myself.
Pickles
Calvin
For sure! Should be fine 🙃 it had no trouble with the weight
JimParker256
Cedar Park, TX
From the "before" mileage estimates, I'd guess it's an EcoBoost.
dalola
Retired
SE Ohio 🇺🇸
Thanks for the great feedback! I find your FE with that trailer pretty impressive, given the aero drag.
Can't wait to get mine, and see how it limit tows.....I'll be right at 4K, but no aero drag (tandem flatbed). My tuned 2.7 F150 would run in the 15-16 range, I expect the Mav to be a couple mpg's worse....but I'll make that up & more while not towing, which is 90% of the time.
Pickles
Calvin
I had cruise set to 70mph on the highway. Its the highest it would let me go staying in the FE cruising gears. It was at about 2100rpm. If you want to drive 80 you’ll be at like 3000rpm. So like driving a 6speed manual sedan on the highway lol perhaps yoir extra weight but no drag would even out to about the same.
dalola
Retired
SE Ohio 🇺🇸
Speed certainly plays a bigger factor with a tall profile trailer. I typically am not in a hurry when towing, plus the roads I drive are not compatible with higher speeds, due to hills & curves. Only thing I'm currently not happy about is Ford's decision to not apply select-shift to the EB/8AT 4K combo. Big miss IMO. Loved that feature in the F150.
Pickles
Calvin
It is odd that there’s no manual mode. Even our 8AT kia has one lol i think you’ll be happy with the tow/haul set up though. At least they did a good job with it
try the same/similar tow in normal mode instead of tow/haul. you'll lose some of the things you liked but it will use more mpg friendly gear selection and shift points.
dcs12345
TX
07 Chevy
“Fuel econ:
as expected, it sucks. For reference i average 30mpg in normal driving. empty trailer on highway i got 17mpg. Loaded through city it fell to 13-14. It could be worse. But dont expect to save fuel by hauling a trailer with this thing instead of a full size truck lol”
Thats not too bad. Hell, my old Chevy 1/2 ton gets around 13-14ish in the city when it isnt towing.
JimParker256
Cedar Park, TX
<snip> Speed certainly plays a bigger factor with a tall profile trailer. I typically am not in a hurry when towing, plus the roads I drive are not compatible with higher speeds, due to hills & curves. <snip>
I just realized that Ford actually publishes the "aero" limits in their towing guide. I've linked it here. (Kudos to Ford, by the way for such a comprehensive towing guide!) It shows that the Maverick has a 20 sq ft maximum frontal area limitation w/o the 4K tow package. With the 4K Tow package, that is doubled – 40 sq ft max. It says "Exceeding these limitations may significantly reduce the performance of your towing vehicle." I read that as "Your fuel mileage will go to hell in a hand basket."
For a 4K Tow equipped Maverick, a trailer that is 6' wide and 6 1/2 ft tall (ground to roof) would "max out" the frontal area limit. That's a fairly small trailer... Anything larger is going to start having significant aero impact to your fuel mileage. From the pictures, I'm thinking the OP's trailer probably is right at that limit, or possibly slightly over...
But now I'm really curious if anyone has actually towed a trailer with 20 sq ft frontal area with a non-4K Tow Maverick, and could report their findings.
