Does Maverick have rear window defroster??
mav_nav
MI
Under Exterior Features on the Lariat trim it is showing
Power-Sliding Rear Window with Privacy and Defrost.
True. But I do not see any heating elements on the glass and there's no button in climate controls either. Gotta call someone tomorrow...huh
Ford Maverick Does Maverick have rear window defroster?? ClimateContols
WhoDatFanMan
Louisiana
Caddy and 2021 Ford Expedition
I think it depends what area of the country you live in. I've lived all over. The only time I've used the rear defroster regularly was in New Orleans.
oh yeah! We got that 90-100% humidity down here on the bayou.
MavrickEcoBoost
2019 Ranger
Thought I saw that....one of those little details that made me pull the trigger on the Lariat.
It is integrated with the sliding rear window. No strips like normal, top and bottom heat and will probably be activated when you put the main defroster on or the mirror heaters.
jcsan18
JC
NC
Dunno if it does or not, but here's a snippet of my window sticker's Exterior features:
Ford Maverick Does Maverick have rear window defroster?? 1635939722568
adawalli
Adam
2017 Ford Explorer Platinum, 2010 Toyota Prius 3
Im confused - you showed us a pictured of actuator and powered window - where did you see a heater in that?
adawalli
Adam
to be fair, Ford did say it had heated rear back in June, but quickly removed it from most if not all documentation. Do any of the current order guides actually mention a heated rear window?
briandefilippo
Chicago
Saw defroster lines on an F250 yesterday!
IPunchCholla
Patrick
Albuquerque
2006 E150, 2014 Leaf
Ford Maverick Does Maverick have rear window defroster?? 95BE254A-E15E-46C4-BDA7-0F6C798E1FDE
It is still showing up on the website for my Lariat Lux.
armerdcatfish
RI
Maverick XL
XL-Trim here.
31-Degrees this morning. Frost all over the truck, back window as well. Took about 12 minutes to clear totally just using heat from inside the vehicle. Once moving, nothing froze to it again, back window stayed pretty clear.
WhoDatFanMan
Louisiana
Lies, obfuscation and inveiglement!! That is all you get from the auto industry aka Illuminati!!!
AUsomTiger
Sweet Home Alabama
2025 60th Anniversary Mustang GT BB #0073, 2022 Maverick Lariat
EDIT: Finally read post #18 above. I think the key is heated vs defrost. I guess I'll get to play with it when mine shows up.
I assume the capability got dropped even though it is covered in the manual and there is even the following warning:
Note: Do not use razor blades or other sharp objects to clean or remove decals from the inside of the heated rear window. This can cause damage not covered by the vehicle Warranty.
OTACORB
DAB
Central, Louisiana
There are conditions that a defroster is necessary, regardless that the back window is straight. Do all pickups not have one? Think Ford skimped on this one.
It was initially part of the Larait Lux Package, but very early on before people started getting vin numbers they removed rear defogger. Not a happy camper because I use it a lot. Oh Well!
whighammaverick
Michael
Whigham, GA
Ford Maverick Hybrid Only
