I would like to turn all this annoying stuff off
It'll be easier for you to just get a '78 Maverick.I would like to turn all this annoying stuff off
https://www.mavericktruckclub.com/forum/threads/forscan-101-step-by-step-how-to-start-guide.7406/I would like to turn all this annoying stuff off
I don't think Ford made the Maverick in 78 i know they did in 77 which was the last Year IIRC.It'll be easier for you to just get a '78 Maverick.
Can someone clarify how to turn on the auto headlights/brights? And stay on? So far mine has been turned on randomly without me being aware I did anything.Forscan can disable auto-headlights . Or basically you set a new 'default' - to Off. I did this for a short while, but then realized I actually liked the auto-headlights.. So its back On.
Auto start/stop can also be disabled by Forscan. I disabled it for a while. But, I've turned it back on as I find it useful to have, sometimes, when I know I'll be sitting at stop lights or in a drive through. But I can't stand AS/S for stop signs. I just use Sport mode when I want to bypass AS/S now. Honestly, I'd prefer a switch to toggle it On/Off as in, not AUTO, but literally, toggle it on as i'm sitting at a long stop light or long drive through, for examples.
Collision avoidance I've had 1 positive trigger (audio only) in a parking lot while reversing out of a blind parking spot, and 2-3 false triggers while driving on the roads.. Just audio tones, no braking or evasive intervention. The false triggers are very annoying and distracting, and probably cause accidents.. While I'm wondering why my dash is flashing Red and audio tones are going off and trying to look around to figure out why its doing it. (Safety that is so protective that its not safe, go figure.)
Door locks - I don't know what you mean? I haven't had any trouble. I approach the door when its locked and when reaching for the handle it unlocks, every time. I open the door to exit the vehicle and i press the lock button inside, or tap the top of the door handle and it locks, every time. Are you experiencing some other behavior? (I actually really like how the locks function, but had similar functionality with my previous Focus ST, so I'm used to it.)
The truck defaults to auto-on headlights and it is not user-configurable outside of Forscan. Every time you start the truck, the headlight switch will be set to "A". Are you wanting to change that behavior?Can someone clarify how to turn on the auto headlights/brights? And stay on? So far mine has been turned on randomly without me being aware I did anything.
And on a side note, you can temporarily disable auto-high beams by flicking the stalk forward when the brights are on in auto mode. This turns off the auto-high beams, until you flick it forward again to enable high beams...then should be in auto-high beam mode again.The truck defaults to auto-on headlights and it is not user-configurable outside of Forscan. Every time you start the truck, the headlight switch will be set to "A". Are you wanting to change that behavior?
The auto-high beam setting can be configured using the dash menu and steering wheel controls. Page 95 in your manual.
Barbara,Can someone clarify how to turn on the auto headlights/brights? And stay on? So far mine has been turned on randomly without me being aware I did anything.
Yes, still the knob.Can't y'all 25+ Mav drivers just turn the headlight knob to "on" also?
Its weird you mention this. Mine only works in Drive. If I change to N or P, the engine auto-restarts. I would kinda like for it to stay stopped in N and P.. But I get why it restarts..Auto start stop can be annoying when it kicks in while you have the truck in neutral.
Not following... you want a button that functions differently than the current button?Yet another reason I'd prefer just having a simple switch to press when I WANT it to stop the engine, and only restart when I blip the throttle.
