Barracuda340
Abilene Tx
The chroming coming off that easily is because its put on with a process known as vacuum metalizing. This is how they "chromed" those old plastic gage trim pieces on old muscle cars. Any of that old plastic that I strip the chrome off of I used to use Castrol super clean. It would strip it to bare plastic in 15 minutes or less. Same process that's used on "chrome" plated model car parts. The ammonia in windex will spot and strip it off too.
NextTruck
PA
2017 JeepGC Overland, 2010 Tahoe
I always wonder how someone figures this out. It's like the invention of the sandwich.
It was when I got mustard all over my fingers.............
OneAlienBoi
Kev
Utah
Explorer
I really want to tint our heads and tails. Would make the truck look stellar.
Dad
what are these bulbs??
https://www.lasfit.com/products/for...verick~yr_2022~zq_lariat~dz_the-whole-package
I will be receiving a Maverick lariat
Can I swap them out myself? And why would I want too?
ty
The bulbs are fairly easy to replace. No more difficult than most other vehicles. YouTube would be great source for how to do it.
As to why, except for the headlights, all of the bulbs for the Maverick's exterior are incandescent which draw more current and burn hotter than LEDs. The bulbs you linked to are LED's which are much brighter, draw less current, and do not get hot. Lasfit bulbs for the turn signals/brakes are more expensive than regular LED's because they have built-in resistance. Explanation and apologies if you already knew this: Incandescent bulbs have a higher resistance which allows them to blink on/off at a certain rate. LED's have a much lower resistance, so the current will stay off for a shorter period of time and they will blink much faster (hyper-flash). The Lasfit bulbs emulate the higher resistance of incandescent and so will blink at a normal rate.
Personally, I think the Maverick's incandescent rear brake and turn signal lamps are quite bright and saw no need to replace them. I did however, replace the back-up lamps and the over the cab lights with LED's. Since they don't blink, I was able to use a cheaper LED without the built-in resistors. I also used LEDs without resistors for the side markers, but opted for the expensive $50 a pair LED's w/resistors for the front turn signals. They are bright enough that I swear I could use them as headlights.
robbyrob
usa
acar
thank you!
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
I really like this mod. I’m interested as I think this will look stellar with the cactus gray. I saw someone else’s post/pic with cactus gray and it looks sweet! I need to head to Lowe’s and get to work this weekend. I’ve got a new tonneau cover coming as well! Might be an awesome weekend for the Maverick!
PeeWee
PeeWee
Jeremiah
Hawaii
‘22 Maverick FX4
Excited for you. Post your after pics when you’re finished.
JimParker256
Cedar Park, TX
Probably by accident. Someone had a chrome part come in prolonged contact with the Zep and said, "Crud, I really screwed this up!", and his buddy said, "Wait a minute, Bob." " I think you're on to something".
You left out "Here, hold my beer..." :ROFLMAO:
  • Haha
Reactions: Dad
JimParker256
Cedar Park, TX
Just go for it, dude. We won't judge you no matter what color you tint your head and ass. But you WILL get bonus points if you color-match to your Maverick! :ROFLMAO: :ROFLMAO: :ROFLMAO: o_O Sorry - I probably didn't get enough sleep last night...
Dad
You''re on roll!
Jamers99
Jason
Tampa, FL
2023 Maverick
Do you guys think the reduced light emission by removing the chrome's more than made up for by swapping out the brake and backup lights with LasFit LED's?
FunctionSpec
Richard
San Gabriel Valley, CA
2022 Maverick HYBRID XLT LuxPkg
There are two posted videos on page 2 for the brake/signal lights using LASFIT LED, one at night and one during the day.
FunctionSpec
Richard
Once you remove the chrome, it's like a "black chrome" surface underneath it. It still reflects light but not as well as actual chrome itself but you probably won't notice the difference unless you put them side by side.
The LED headlights uses the chrome surface of the reflector to reflect light off of to give an even beam pattern and cut off point.
