Red454
Indianapolis
2011 Fusion, 1972 Impala, 2005 Mustang
I used some 80/20 Aluminum extrusion to make the side rails. I designed some sliding hook mounts for the 80/20 that would use the stock tie-down hooks. Next step after the test fit is to get them anodized. In the center is an M8 tapped hole for maybe an eye bolt.
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_4095.JPG
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_4090
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_3878
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_4091
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_4089
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_3950
SVTRIDE
SE Michigan
2024 XLT Maverick
Nice creative work.. Nice to be able to truly make what you want. Thanks for sharing.
Are the 4 tapped screw holes in the slider corners the means by which you “clamp” the slider in the desired position on the 80/20 extrusion?
Versus L-track brackets mechanically lock into desired position.
Red454
Red454
Indianapolis
The corners are counter bored for M6 screws, and those screws thread into a plate that is tapped for M6. The plates slide into the two T slots in the extrusion. So you loosen the 4 corners, slide it into position and then lock them down.
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts 1717682056851-am
timcal
mass,usa
xl maverick
Do you have a drawing with dimensions for the rails also?
mav_kev
PA
Mav
Ok this is freakin' clever! I may have to steal this. Well done sir!
Red454
Red454
Indianapolis
Yes - sort of: initially I was going to make the rails out of stainless angle iron but then I found the extrusion. I never made a drawing for the extrusion.
The second hole from the left had some issues for both sides of the bed. The position of the threaded inserted welded into the bed at the factory was off somewhat vertically, so there was not enough room on my extrusion slot to make that work, so I used very short bolt and just glued it in there for looks. It’s not perfect, but it works. I added the picture of the misaligned holes so you can see what I’m talking about. I believe this issue has been noticed by other Mav. owners. For those using the larger B channel (like unistrut) for the side rails, the slots in the channel are large enough that the misalignment doesn't matter.
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_4101
Ford Maverick DIY Custom Side Rails / Tie-Down Hook Mounts IMG_3919
Hot Runr Guy
West Chicago, IL
Genius. Pure genius.
HRG
Crash11
NA
2024 Maverick XL Hybrid
Awesome work.
Red454
Red454
Indianapolis
Nice. What about extra anchors or attachments for the stock rails? Willing to make and sell some?
Wish I could but access to materials and equipment is limited.
Blinky
Alberta, Canada
I think some of the holes are intentionally offset, the first and second hole from the front on both sides of my truck are offset vertically from the last two holes.
Between that and the odd spacing it's a little annoying as I'd intended to mount some L-track but I guess I'll make an adapter plate of sorts.
