Bry
Bryan
Mission Viejo, CA
Maverick XLT Hybird
Since I installed my roof rack on the side rails, I can't slide up the divider. DIY bed divider with lockable hinges. I used a lighter weight 1x8 pine wood x2 cut to 54 1/4, lightly stained black. Cut in half and install lockable hinges for easy removal. Cheap hinge a pair for $12
Amazon link for the 180 degrees
https://www.amazon.com/Skelang-0°-90°-180°-Foldable-Extension-Workbench/dp/B0BN7YJT1V/ref=sr_1_1?crid=11FSI5AH5V52Z&keywords=Skelang+2+Pcs+Folding+Brakcet+0°-90°-180°&qid=1687957527&sprefix=skelang+2+pcs+folding+brakcet+0+-90+-180+,aps,111&sr=8-1
Ford Maverick DIY bed divider with lockable hinges 0
Ford Maverick DIY bed divider with lockable hinges IMG_4022
Ford Maverick DIY bed divider with lockable hinges IMG_4024
Wt267
Usa
Acura TSX
My maverick is scheduled to be built in august and I’ve been looking for some type of bed divider option. This is perfect and low cost. Thanks for sharing!
FriscoTXJoe
2022 Maverick Lariat
What is the purpose of the hinges? I have a standard 2x6 painted matte black in mine. Your's is pretty but not seeing the reason for the hinges?
MAVRICK
Any
2024 XL
DIY bed divider with lockable hinges. I used a lighter weight 1x8 pine wood x2 cut to 54 1/4. Cut in half and install lockable hinges for easy removal. Amazon $12 for pair
https://www.amazon.com/Skelang-Brackets-Extension-Foldable-Hardware/dp/B088LXDGM8/ref=sr_1_21?crid=15W7347IEWQNK&keywords=lockable+hinge+2+pack&qid=1687789272&sprefix=lockable+hinge+2+pack,aps,124&sr=8-21&th=1
Minor "look out for" ... the referenced link lands on the 90 degree option by default ... if/ when ordering - make sure you select the 180 degree option.
https://www.amazon.com/dp/B07G2BXCJF?psc=1&smid=A2TLACOWV5BMIK&ref_=chk_typ_imgToDp
MAVRICK
Any
2024 XL
More flexible handling? ... space saving storage? ... lighter weight? ... if you are happy with yours, more power to you.
thyITguy
Robert
El Paso, TX
@Bry thats pretty damn innovative . If i had that i'd be able to fold it up for stowage. under backseat on on top or fenderwell in bed with longer items flat
FriscoTXJoe
I wasn't criticizing his work, I was asking the purpose. If the board is bent in the middle, it offers some flexibility but not an increase in space. Does it? Hell, I am not an engineer.
rclee
Rob
Dayton Ohio
pretty slick! Now you don't have to go back and forth unwedging the board out. Just unlock it and slide it out.
adsandiego
Tony
San Diego
'24 MAV
the description says 'for easy removal' but ... it's just as easy to lift and remove an uncut piece, and save $12, imo.
Barracuda340
Abilene Tx
I will as soon as I weld it together
No joke. It's not going to be wood. The center hinge on the OPs divider, I have already thought of that a few weeks ago. I have 3/4" square tube for the frame, and expanded steel screen. Heavy duty hinges and latches. Cant decide on gloss black or silver.
imboden013
West Memphis AR
2024 & 2025 Mavericks
I thought about doing that, but decided I’d get my fingers pinched every time I snapped it in place.
Bry
Bry
Bryan
Mission Viejo, CA
Maverick XLT Hybird
