Dash covers difference between 22-23 to 24?
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
Is there a difference in dash from 22-23 to 24? Canadian Amazon says the Fiilines one I want fits 22 & 23 but not 24, too odd! Thanks.
EffNo50
Central California
I don't know what the difference would be between '22 or '23 and '24.
Does it have free returns?
I have this on my '24 Lariat Hybrid:
https://www.amazon.com/dp/B0CM9R1CLR
Currently unavailable and hasn't been for some time. The picture on Amazon doesn't show the cutouts on both sides, but they are there. It's a black carpet on top, with little silicone dots on the back to help keep it from sliding around.
dmopro
Richardson, TX
That’s the one, thank-you Glen! $45.00 here in Canada!
No problem Jay.
It was rolled when I got it.
I unrolled mine put it on an ironing board and steamed flat it with a flower sack type towel over the top of it, so as not the scorch it.
Take your time with it.
I have never had to use any sticky tape or any velcro to keep it on my dashboard although. I do have the Mabett soft-touch dash tray. It helps hold it in place somewhat
Good luck
GB
Ford Maverick Dash covers difference between 22-23 to 24? IMG20240901104649
lm126027
Larry
Central MA
2024 EB
bought for my 2024 Lariat. Tried ironing out the creases from shipping, but still had some when put in the car. Just left it on the dash for about a week and almost all the creases were gone (all gone now). Did eventually use the stick things to hold on the sash as the very center near the windshield did slip out of place. Put two there, two in the far corners of the dash and two around the pod right in front of the driver. Seems good and now perfectly flat.
Rockyx-
Rocky
Ohii
Subaru
What is the benefit of the dash cover?
🤔A lot of folks me included, report the dash of their Mavericks becomes quite sticky in hot weather. It can get to be 117° where I live. Dry cleaning a sticky dash without getting any lint on it and you'll understand why we cover dash covers.
I'm not alone I think the following post kind of sums it up
Yes, the interior plastics are very soft. The trim in the door openings is especially susceptible to scratching. My lower door panels are also scuffed up.
I don't have any scratches on my dash from what I can tell but the dash gets extremely sticky in hot temps and sun. I have a bunch of dust and pet hair stuck to it.
EffNo50
Central California
It's supposed to help with the heat build up in the vehicle and help protect the dash from sun/heat damage. I like the reduction in reflection on the glass, but you need to pick a dark color without "sparkles" like some of the velour fabrics have. Keep the glass clean, as the plastic gas haze that builds up increases the reflections also.
Keith
Woodbridge, Va
2025 Maverick Tremor
The only problem I see with this mat is it will also cover up the dash speakers with the B&O upgrade. The tweeters are not covered, but the other three are. Might mute the forward sound a bit.
Keith,
Do you have a picture that shows where the dash speaker is with the B&O upgrade? I have an XLT so I don't know where they're located.
Ford Maverick Dash covers difference between 22-23 to 24? 20250626_081312
It seems all the speaker locations are open on this dash mat.
Red Eyes - Wide Shut
West
2024 XLT
Being black, it seems this would create more heat build up
Granted it wouldn't be directly on the dash plastic.
Daveinva
Washington, D.C.
2025 Maverick Lariat Eruption Green
That's the one I got, no complaints at all, no muffled sound. I don't have problem with the heat, but it significantly cuts down the glare on the windshield, and keeps the dash from scratching (which of course only matters for resale, as I can't see my dash with a cover on it!).
EffNo50
Central California
I have the Lariat with the B&O system. The cover I linked, and have, seems to allow the sound through just fine. I might have adjusted the balance and fade some. My biggest upgrade was to the source and I found that out with my prior Fusion that had the factory Sony system. XM from the antenna is not a quality source. There is a lot of compression and missing frequencies. The app is supposedly better but I don't have an unlimited cellular data plan. I ripped all my CDs to FLAC and the quality is much better. I really notice it when a song has symbols. They "ringggg" like they are supposed, to instead of "tink"
