WNYEscapee
TJ
BFLO
2023 Maverick, 2019 Cherokee
Looks great! I was hoping someone came out with something like that, though I bet it would look at good or as durable as what you created. Nice job!
Solo
Wisconsin
'24 Maverick XLT Hybrid
Sometimes it's the small details that make a big difference. This is a clever project (the mesh and the foggys), with very cold results. I'd used some of the aluminum mesh to fill in the gaps on my convertible dolly, works great and had already come in black (mine's a diamond pattern). Useful stuff. 😎👍
metomwhou
Stuttgart, Germany
2021 C8, 2016 HellCat, 2014 Nissan Frontier-V8
Great idea and execution! I have something very similar on my C8 to protect the front coolers and people use almost the exact product for 911 GT3's....
Ford Maverick Custom lower bumper grille insert I added to my 2024 911 grill insert.JPG
Ford Maverick Custom lower bumper grille insert I added to my 2024 C8 grill insert.JPG
So to all the folks warning of reduced cooling capacity...Noted. I highly doubt any perceptible degradation in performance would be noticed on the EB's and the debris protection would far outweigh that....IMO.
jerrisn
NE
2023 XLT Hybrid/2025 Explorer/2018 Volt/2011 Fusion Hybrid/08 Tundra/00 MustanGT
Did my DD Fog Light install this week and since I had the front bumper assembly off there was sever other things I wanted to address the bumper the horns and the backup alarm… First it was the large opening on the lower grill.. Have been considering what I could do to make it look better ever since buying the truck in May.. Well last month I came across this 6mm octagon aluminum mesh while searching the web for something to add to my fender badges… It looked like it would work perfect for the lower grill so I snagged some off of Amazon..
First I made some rough measurements and cut a piece to do some more detailed measurements and bends..
I put a bend in the upper portion then marked it and bent the lower…
Then it was onto the sides contouring it around the plastic opening… When I was happy with the fitment I then shot it with some black primer and then several coats of satin black paint…
Now I just needed to figure out how to attach it, had several ideas… First thought was to pop rivet it in place but I didn’t really want to see the rivets… Then I thought why not use some thin safety wire and secure it to the vertical risers on the grill opening, unless you have your face up in my grill you’ll never even see them….
Cut and bent 8 of them hit them with some satin black paint…
Installing it was just that easy just fished the wires from the front around the vertical riser and twisted them tight, trimmed the excess and tucked the wire out of harms way….
Installed ready to go back on the truck…
This is the screen I used for my Chevy Volt to prevent road debris from hitting the lower radiator. This vinyl coated and does not need to be painted. They have one for the Maverick.
https://voltstuff.com/store/ford-maverickscreen/
Tbone289
MO
Hey HSBII while you had the bumper off did you see where tow hooks could be mounted ?
This video details the differences. Only the FX4 has the rear tow hook mounts welded to the unibody.
thev8man
Booyah 👊🏽 😁 👍🏽 🇺🇲
Love your fogs too
jebourquin
Thornton, CO 80233
2024 Maverick XL Hybrid
HSBII
HSBII
Sam
2017 Super Duty 2024 Maverick
