Maverickman74
Shane
Maui HI
OP make sure you pull that off and put several coats of paint on all your cut edges. Galvanized is a coating not and alloy. It will rust. I would have used aluminum sheet possibly diamond plate although that is harder bend the tabs where the diamonds are. HD and Lowes both sell 24x24 sheets of aluminum in sufficient thickness to be strong.
mcc63303
mcc63303
St. Charles, MO.
sold 22 Hybrid XL now 24 Hybrid XL, 57 Chevy 454ci
Aluminum is certainly an option, if thick enough, will check it out. Maui huh... been there numerous times for vacation.... great place.
Maverickman74
Shane
Maui HI
Come out to Twin Falls and I will chop you a coconut🤙
johnpbrewer
Chaska, MN
2008 Ford Ranger
I've made a filler panel to prevent water/snow/dirt and what ever from going up behind the left rear tail light assembly. I used Galvanized Steel after making a prototype out of cardboard. Had to make sure to give more than enough clearance of wiring so as to not rub. Thought I could use the one bolt at lower inner fender side but the nut (10mm) is not a nut that can be removed, believe the nut is part of the bracket and the bolt comes through from the outside. Now I have a clip to attach the panel to the bolt temporally, will try something different later. Used the one large bolt (18mm) in the frame at rear of the panel to hold the rear, drilled new holes to secure more areas. I may just cut off the rear leg of the panel (but it does give extra support), don't think it's really needed except for extra support. Be careful if you work with any sheet metal, cuts skin very easy! OH, no rattles or squeaks heard...yet!
I've added more information later in thread.
Doesn't adding the cubby hole sorage bin accomplish the same thing?
nickmav
nick
canada
jeep
Nick, I wish I was in a position to make these for others but I'm in the middle of a Major restoration of my 1957 Chevy. I've spent the winter stripping the car down to bare metal again (1st time was 48 years ago) and after taking every piece off I'll finish painting it this week and start the process of assembling it which will take many months.
Everyone, get yourself some galvanized sheet metal (I bought the 2ft x 10ft roll from Menards for around $28) and after making and fitting a cardboard template use tin snips to cut it out. A drill and some screws and you're off and running.
One thing I've not mentioned before is after you make the panel you flip it upside down for installation.
beautiful!
Chris_G
NOVA
C-6 Corvette
Dun4791
Vincent
Tennessee
Chevy,dodge, ford,vw,honda
Hopefully the cubby will be standard next year if nothing more than because of the space without it.
Mymaverick2021
Steveo
Hilo Hi
No, my Maverick is a Hybrid XL.
I was thinking I should specify that incase it was only on Hybrids... I would think all Mavericks have the same issue however.
I'm thinking if you added the Inverters to your tuck that they install it in a cubby like is on the right side, Someone posted that same issue with the sno,mud and water he bought a cubby from Ford and installed it and seems to solve that problem. Not everyone is as talented as you on fabricating a panel like you did so there are options!!!
mcc63303
mcc63303
St. Charles, MO.
Absolutely there are options. Mine is just one possible. Does anyone know the cost of the cubby, what is involved in installing one and does it completely cover the area as the passenger side does?
L Martin
Raleigh
LuxLariat 2.0 cactus grey FX4
Lariat without Lux has cubby on both sides. Does the driver’s side cubby on the non-lux Lariat have some kind of heat shield?
Mymaverick2021
Steveo
Hilo Hi
I just Googled it and you can order one from Ford for around $40.00 part#AZ6Z-60286A72-A it will fit the left side compartment by simply removing the existing cover, And just like that solves the problem and + you get added storage in the bed😉
7Litre
Robin
Maine
2020 Sonata Hybrid, 2023 Maverick XLT Hybrid
If I were to get an aftermarket SIBL, when my truck finally gets built, would I want to have the cubby installed first? I love the engineering involved with the fabricated shield but the cubby would be the easy fix it seems.
2022EOW
Marty
Missouri
2014 Focus
I feel you're over thinking this. With at the rear of the exhaust I don't feel heat will be an issue. It would be very difficult to get any tile to adhere and stay adhered to the somewhat flimsy metal and really no need for anything stronger. The galvanized steel should wash off as easy as anything.
Agree, it’s not re-entering earth orbit.
JRPhawk
Jamie
Ford Maverick XLT
Genius! Great work and thank you for the template!
RicksMaverick
Rick
Westfield, IN
Rapid Red 2022 Lariat Lux 1$tED 4k AWD
I thought about aluminum, thought might be too flimsy, so I went the galvanized steel, definitely stronger and won't dent as easy. No doubt will get rocks thrown up from the tire.
Salt eats aluminum if not anodized, primed & painted so if he gets winter, not good choice.
