- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
The tank is exactly the same.Unlike the EB, the Hybrid gas tank is hermetically sealed. Pressure builds up as the gas expands from heat etc.
How & Why does a perfectly working gas pump click off
when there are still gallons of space remaining in the Hybrid’s tank?
It is not a malfunction - it is a purposeful complex engineered EVAP system designed to trap the extra vapors generated by the slow gas sipping Atkinson engine.
I say screw it and use the same tank & EVAP system in the Hybrid that is used in the EB.
I'm not supplying the pictures again - anyone can find them on ebay, with stickers showing which model they go to, because without stickers you can't tell.
The controls on a sealed tank are likely very similar as all are supposed to be for decades - no venting except when fueling.
You got the wrong side of the tank.
It's not taking more fuel above an EB tank level.
It's got more on the bottom after reading empty.
I wouldn't be surprised if most the components are the same for the EVAP system - just different required pressures for tank.
Fuel pump different for DI required pressures obviously.
