Carplay issues
jsalewicz
jsalewicz
Indiana
2023 Ford Maverick XLT Hybrid
lol it’s crazy for sure! At least I know I’m not alone
vinnymac
Vince
I've got the same problem in my '22. It's always been there. Multiple iOS versions, multiple head unit software updates, multiple cables (usb and usb-c) and it's still a problem. And that's if CarPlay starts up on the first try, too. Sometimes it'll take 4-5 minutes, or multiple reseatings of the cable to either the phone or the USB port. Bluetooth works just fine though.
The good thing is that my wife knows not to answer the phone the first time I call her when I get off of work. The bad thing is that sometimes I get an incoming call from someone else before I call her, and have to do the whole dance and explanation that Ford builds technology-handicapped products.
this cured all my issues with CarPlay
Ford Maverick Carplay issues F52C9BF1-BA18-4761-BA77-C23FD23E78DC
Dirt820
2022 Maverick XLT
You’re right, I need to give these another look.
If you have that plugged into the usb port, and then plug the phone into the other usb port to charge, does the phone CarPlay supersede the wireless unit, or does it only charge the phone?
Ozarkbeard
vinnymac
Vince
i have only used Bluetooth but direct wire to USB port will probably knock out Bluetooth. I’ll try both myself and update
vinnymac
Vince
So far still works just a little slower to hookup so turn off Bluetooth and plug it in and you charge and listen to your music 👍
Mini One-Fiddy
Jax, FL
'23 Bronco Wildtrak. '23 Maverick XLT BAP Hybrid
Whenever I make a call or receive a call the first time it doesn’t go thru but 2nd time it does anyone else have an issue with this?
Yes!!! Ever since day 1 back in January.
jsalewicz
jsalewicz
Indiana
I seem to have less issues when I follow these steps. Get in truck, buckle seatbelt, plug phone in, put key in ignition. Start truck. Press OK for ok to drive and ok to seatbelts. Phone connects quickly.
my 2017 Flex had a few quirks with connections from time to time but nothing like this! Sound will go mono sounding Bluetooth is all jumbled and digitized.
I love this truck but phone connection should be so much better.
There are times I just listen to the motors to help me become one with my Maverick 😉😂
But may have to get that wireless connection that was posted here.
jsalewicz
jsalewicz
Indiana
USB trumps Bluetooth
Mav_RICK
Rick
Arizona
Ford F150
I think the cords are a big issue here whether it be when you connect your phone directly with a cord or if you use a wireless adapter that has a cord.I use a cordless CarPlay adapter that plugs directly in to the usb port. I say avoid cords and plug straight in.
As Ozarkbeard said above get an adapter for the 12 volt outlet as your phone charging point. That’s where you should charge your phone if needed. You can then charge and be connected via Bluetooth simultaneously. Also if you go the wireless CarPlay route unpair your phone from the truck because you are going to have the adapter paired to the truck. The phone connects through the adapter.
vinnymac
Vince
the anyfar adapter took all the issues away,phone and CarPlay work great!
jsalewicz
jsalewicz
Indiana
I plugged in and left Bluetooth on it still worked but much slower so it charges and plays
You plug into the cigarette charger port right?
jsalewicz
jsalewicz
Indiana
Yes every dang time!
