Bypass Tailgate Lock?
Ontario
Tacoma Ranger F350’s
Can it be done. Really annoying; I lock my keys in truck with keypad and need access my bed several times at work
peepsnet
Don
Naples, FL
2018 F150 5.0L V8 STX / 2015 Explorer XLT 3.5L V6
Ontario
Doesn’t that just add a tailgate lock? I have one. I want to bypass it. I don’t want to use my keys to have to open it
BeardedK
Kevin
22 Maverick XLT
I don't think you can do that, unless you're willing to disconnect the power lock at the tailgate.
Might be worth keeping the key blade on you though. That way you can 1. lock the fob in and then unlock the tailgate and 2. unlock your truck if your battery/keypad shits out.
TSAINTS1115
While unlocked take the access panel off and disconnect the lock.
Ontario
Yea. But not all the time. Just when I’m working and need quick access to bed.
I thought there might be a setting for bypass
TSAINTS1115
Other than putting a toggle switch in the tailgate harness to cut power when you want it to stay unlocked there is no "have it both ways" solution.
peepsnet
Don
Naples, FL
This would allow you to use the keypad to open the lock. Just follow your door code with 3/4 button to unlock all doors.
Ontario
Better. Still not ideal but somewhat better
Seems like when I got my lariat First edition I had to change settings to get my tailgate to lock using my fob. I'll check manual when I get a chance.
Ontario
Bed being separate from cab there should be a way to do this from settings.
I believe newer f250-350 and possible 150’s have the ability
Jmav2152
Jamie
Cleveland, OH
Well its a unibody so technically they are not separated.
The F series does not separate this, what it has is a function to open the tail gate with your fob and it auto lowers and closes. I mean just carry your FOB on you and have a detachable lanyard to leave the rest of the keys in the truck.
just to further tame expectations even SUVs with hatch doors dont operate like that unless you have keyless access and again have your FOB on you to trigger the button.
Ontario
sure technically its not separated but its a truck bed, not part of an SUV. Lots of tradesman use the bed when truck is locked
