Bronco Sport (Big Bend) Wheels
TQM
Texas, USA
23 Maverick
I got my Maverick with steel wheels, but always planned on replacing them (I don't like the look). After watching for a couple weeks, I finally found some Bronco Sport (Big Bend) wheel and tires (new takeoffs) that were local to me and at a good price. I'm very happy with them. Nothing that hasn't been seen before, but I figured I would post what I noticed for anyone going down the same road.
Ford Maverick Bronco Sport (Big Bend) Wheels PXL_20230617_163517431
Ford Maverick Bronco Sport (Big Bend) Wheels PXL_20230617_155659379
I read a lot of the post here on lug nuts and such for the Bronco Sport wheels (including the long argument thread :p). I chose to use Gorilla Wheel Locks. I'm happy to say that they fit nicely. I can see what some people say about the OEM lug nuts from the steel wheels "not fitting right". I think they are safe, and don't think they damaged the wheels, but they do not feel like they fit as well as the Gorilla lug nut I got. I went to a shop to get the TPMS's switched over and the new wheels balanced. The tech there also commented about the OEM lug nuts not feeling like they fit right (I had they use the OEM lug nits because the ones I ordered hadn't come in yet).
I looked at getting normal lug nuts plus a set of 4 locking nuts, but ended up just getting the Gorilla set of all locking lugs. It was about the same price since most of the lug nut sets I was looking at were around $30, and the 4 locks were generally $35-$40. All the wheel locks I have used before were the McGard style ("flower" cut-in on the end). I have to say the Gorilla locks around the circumference feel much more secure when torqueing on the nut. They just have more insertion and don't feel like they will slip out on accident.
I bought the 1.5" length nuts, because that is what most people seemed to recommend here. I didn't want to risk having to return something that did not work (had also been looking at 1.38"-1.45" closed lug nuts). The 1.5" are more than is needed, and shorter ones would work fine. The open OEM nuts are just over 1.2" long, and the studs do not come out of the open end of the nut when they were used with the Bronco wheels. Aftermarket lug nuts may engage deeper in the wheels than the OEM (the "feeling like they fit better"), but its probably not much. The 1.5" ones I got are longer than needed, but not so much that it bothers me. If I was to order again, II think I'd feel comfortable getting 1.4" or maybe even 1.35" nuts. Here is a picture showing how much the 1.5" nuts extend.
Ford Maverick Bronco Sport (Big Bend) Wheels PXL_20230617_172043519
The Bronco wheels came with Bronco center caps, so I got replacements on Amazon. There are a variety of styles available. The 54mm outer and 50mm/51mm inner fit perfectly.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
I think they look great.
JBryant
Jesse
Bowie, TX
They look great and glad it worked out for you.
Midwest Jim
Iowa
Ridgeline CRV
I did the same after I hit something on the interstate and ruined a tire and steel rim. The Ford dealer wanted over $500 for one steel rim, more than I paid for a set of Bronco Sport wheels/tires with 1000 miles on them.
Ford Maverick Bronco Sport (Big Bend) Wheels IMG_20230509_143258900
Dude84
23 Maverick XL Hybrid
These look nice. Will the Bronco Sport Big Bend wheels work with the stock Maverick Continentals? I found a cheap set off takeoffs nearby, but they're just for the wheels. I should be good, I would just need to get the gorilla lug nuts linked above?
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
Where are those center caps from?
HTX
Jon
Houston TX
CR-V
Looks good. Great post for XL folks!
jsus
2022 Ford Escape Hybrid AWD
I think the Big Bend wheels look great - anyone know the wheel weight on these?
(I have yet to find a good answer scouring the web - annoying!)
Ford claims 25.75 lb, though that may or may not include packaging.
Ford Maverick Bronco Sport (Big Bend) Wheels 1691782184120
Formula11
Nj
XL AWD AREA51
Falken wildpeaks AT3 245/65/17
surfstar
2023 XL Hybrid
Added BS Big Bends that came with Continental ATRs OEM 225/65r17 (new-ish soft-road tire, that seems the lightest in its class - hopefully for better and not worse!)
Steelies + ProContact tires = 49.5-49.8 lbs
BS Big Bend + ATRs = 46.2-46.5 lbs
Ford Maverick Bronco Sport (Big Bend) Wheels PXL_20231105_235042559
Ford Maverick Bronco Sport (Big Bend) Wheels PXL_20231104_235948611
JP4AZ
Phoenix
Just and FYI. I just saw a full set of "Big Bend" wheels on the Phoenix Craigslist for $250.
