Bronco Sport Wheels
Demonkyn
Georgia
2023 Ford Maverick
If I buy 2021 Bronco Sport Wheels for my 2023 Maverick. Can I use my current lugnuts or would I need to buy new ones? Also would I need to TPMS switch the sensors out or just program the ones in the Bronco Sport? Thank you in advance, I am not sure if I am posting in wrong section I am new to this forum.
Cancunbadlands
Cancun
Cancun
Use your current lugnuts.
You can program them using ForScan
Easier to switch them tho
Busa789
Dennis
Iowa
2025 Lariat
Discount Tire has always reprogrammed my sensors for free.
Johnkn
MD
The early Bronco Sport uses the same 315MHz sensors as the 2022-24 Maverick, correct? Why would they need to be programed with ForScan or switched?
In probably my last ~7 recent Ford F150s, Explorers, (3) Mavericks, Broncos, etc. where I've swapped wheels, installed new wheels with new OEM Motorcraft sensors, or did a tire rotation, every one has self-learned within ~10 miles and/or a couple key cycles...
thanks
Cancunbadlands
Cancun
Cancun
thanks
He has a 2026? Or a 2022?
Johnkn
MD
Cancunbadlands
Cancun
Cancun
Roger that. It will be an easy swap. The BS sensors will work then
