Brake Grinding Sensation
SM2535
NH
2025 EG Hybrid Lariat AWD
Hey all -
Has anyone else experienced a "grinding" sensation/feeling when pressing on the brake pedal? Curious if this is something to be expected during break-in, or if this is something I need to go back to my dealer with.
kw86er
KW86ER
Vancouver BC
2L XLT FX4
It's not antilock kicking in? Is it every time or only under certain conditions?
Darksider
Here
Two
Doesnt sound right. Get it checked out, you dont want to be second guessing your brakes.
SM2535
SM2535
NH
SM2535
SM2535
NH
Is this after periods of sitting especially when moisture has been present? The rotors will develop slight oxidation and will briefly make noise until a couple of brake applications scrub the surface clean again.
No, it seems to be persistent. Granted, I've only had the truck since Monday, but I've noticed it pretty much every time I drive it.
bgillen35
Brendan
St. Cloud, Fl.
'24 Maverick XLT, '22 Indian Chief
Take a look at your rotors. Are there visible score marks on the inside or outside? Could be something as simple as a rock or debris stuck between one of the pads.
If there are no score marks, try a couple of higher speed hard brake applications to try and scrub the pads clean. I don't know what type of pads come standard but depending on what they are, they could be noisy for the first hundred miles or so.
Clarkdonbran
Did I miss if you said hybrid or EB? The regenerative braking feels like grinding to me.
SM2535
SM2535
NH
I'll have to check that out. Appreciate the input!
kw86er
KW86ER
Vancouver BC
2L XLT FX4
If you suspect that it's a rock, drive it in reverse while tapping the brake. First lightly and then harder. This generally works to remove the rock the way it got in.
Champ
ML
Mustang GT, Miatas, Z06, Outback
A single pad might have been put in backwards [metal side in], or cocked or the wear warning clip might have been bent in. I've seen all happen over the years. If in the rear, everything feels OK, just the noise when you hit the brakes! Car still will stop fine,---- for a while!
Mymaverick2021
Steveo
Hilo Hi
Hey all -
The sooner the better FUNNY NOISES NO GOOD
teebandit2
terry
Cincinnati
2022 ford maverick fx4 xlt 4k tow 360 copilot
right. mine does the same thing. if it's sat a little bit and damp out sounds like the front passenger side brake is grinding. after a couple minutes of driving it seems to go away. thinking of taking it in to get looked at
