Brake Creep Groan?
retiredmike
ohio
2024 Maverick lariat
Any service bulletins on Brake Creep Groan?
Jah.
Jah.
Central Florida
Mine does it early usually once until it warms up I guess using auto brake hold .
Beekeo
Massachusetts
2022 Ford Maverick, 2018 Ford Escape
Yeah cold and wet brakes can be quite noisy, but once they’re warmed up they are quiet
Are you hearing the groaning noise consistently?
retiredmike
ohio
No. Letting off after a stop. Service writer where i bought it said it's do to the metal in the pads. Nothing they can do. I think he meant under warranty. With 6,000 miles, it has subsided a lot.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
I've heard rumors (involving other vehicles) where upgrading to ceramic pads can help this stiction issue if it bothers you enough...
retiredmike
ohio
no
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
The problem is that the factory pads are hygroscopic, and when cold and damp they will groan. Its normally worse in reverse, as the anti-squeal shims are only set up for forward motion. Aftermarket pads do not do this. If it still does this after a few miles and are warmer, then maybe you have a stuck brake that needs the sliders re-lubricating.
Ozarkbeard
I have heard this when backing out of the garage on a cool and/or damp morning. But not very often, and it always goes away.
retiredmike
ohio
retiredmike
ohio
Somewhat. Happens at very low speeds (creeping).
retiredmike
ohio
Shouldn't have to upgrade brake pads.
retiredmike
ohio
After approx. 13,500 miles, the BCG is about 90% gone (for now). Must have worn down the metal in the pads. What a relief.
