Blue Ox Base Plate Failure! Public Service Announcement
BradnChristine
Brad
Wyoming
Add one more Blue Ox failure. Braked, no even hard and the driver side receiver is bent! I ordered a new one but will not install it. Based on threads, going with a Demco!
I've made several trips now towing with my Demco baseplate. Tomorrow will start another 2500 mile trip. About 6500 trouble-free miles so far.
Twinboat
Roger
NY
2007 Jeep
Came up with a idea, and implemented it, to brace my BluOx baseplate. Although I have a longer arm towbar, and not had an issues with it, I figured it's cheap insurance.
I ordered a 1" X 2" X 4 ft, 1/8 thick box beam and 2 - 4" X 4" X 1/4 " thick steel plates. Drilled 1-1/2" holes in the plates, rounded the corners and welded them to the box beam at the proper spacing.
I slip it over the adaptors pins and hitch up the tow bar to keep it in place.
Ford Maverick Blue Ox Base Plate Failure! Public Service Announcement 20240930_134811
Ford Maverick Blue Ox Base Plate Failure! Public Service Announcement 20240930_134755
Hot Runr Guy
West Chicago, IL
Well done! HRG
realshelby
realshelby
Houston
1969 GT 500, 1965 Mustang GT,
What brand/model towbar were you using?
Charlie23
Charlie
Lariat Maverick 2023
Blue 0x. Blue ox said I need one 2 inches long but they will cause base plate to bend also with enough stopping force. Problem is the spread is 41 inches and no tow bar will, regardless of what Blue Ox says, will prevent the base plate from being bent. Was just at a Tiffin Rally and before I could tell people I bent my base plate, everyone said do not put a blue ox on a Maverick. They will bend! Replaced with a Roadmaster. Only 28 inches wide within industry standard.
realshelby
realshelby
Houston
Blue Ox will tell you they offer 2 or 3 tow bars that are recommended. They have legs about 2" longer than the Blue Ox towbar I had, and likely the one you used. Two problems with that. First is that there is already confirmed failure of the Blue Ox base plates USING the recommended length tow bars!!! Second is that NOWHERE in any of the literature or mounting instructions did is say a minimum length towbar is required. "Compatible" tow bar was all that was stated, and my Blue Ox was 100% compatible in fitment. Language has been changed, but STILL does not confirm what a customer must use to prevent base plate failure.
Blue Ox has denied all claims as far as I can tell with the slight exception where they sent a customer a replacement base plate package ( no compensation for labor) for his failure ( while using the recommended length tow bar). Blue Ox refuses to acknowledge the flaws in this design and continues to sell them.
BradnChristine
Brad
Wyoming
Yeah...that's the end of my EVER considering any Blue Ox products. Failing to warranty an obviously BAD design is terrible customer service. Their engineers made a mistake; they should own up to it.
shadow76
bob
TX
F150, Ranger
After reading the issues with tow bars, tying into the electrical and braking systems, elected to go with a tow dolly equipped with surge brakes.
Towed the Maverick nearly 4k miles this summer without an issue. Takes about ten minutes to drive the truck onto the dolly, strap in, attach safety chains and plug the dolly into the RV.
As I chose to tow any one of three different vehicles, the tow dolly made economic sense vs a tow bar set up for each vehicle. Additionally I have sufficient room to store the dolly when not in use.
kbausman
Karl
Mission Tx
2024 Maverick Hybrid
I had the exact same thing happen to me. And of course Blue Ox denied my claim. This is a very poor design. There are also Jeep owners that have had the front bumper mount crack at the weld from the same type design. I won’t ever be recommending or buying another blue ox product again. My next move is to file a claim with the NTSB.
kbausman
Karl
Mission Tx
I
I have also filed a complaint with the NH
I have filed a claim with the NHTSA. I urge all others with this condition to do the same.
BradnChristine
Brad
Wyoming
I
The fact that Blue Ox has now changed its baseplate due to MULTIPLE failures as reported here is full evidence that they KNOW they had a defective product. Yet they still don't stand behind the failures, unless they've recently been doing so with NDAs.
Blue Ox will never get any business from me, after listening to all that has been reported here. And as far as I see, bolting an extra piece is a very poor "fix". Baseplates should have both sides (connection points) welded onto the crossbar for many applications, including the Maverick.
kbausman
Karl
Mission Tx
I had the blue ox front packets mounted to my maverick. I didn't even get nine miles before The front of my truck ended up running into the back of my motor home. Both the brackets we're pushed outward, just as described in previous post.
I would happily be part of a civil action suit against blue Ox. They should not be allowed to knowingly keep selling this inferior product. Them and e trailer.
file a report with the NHTSA
kbausman
Karl
Mission Tx
Please file a report with the NHTSA
Dave O
New Smyrna Beach Florida
All (3) major baseplate manufacturers are struggling to fit the refreshed 2025 Maverick Lariat AWD Hybrid with a compatible baseplate due to Ford relocating the ACC Radar hopefully Demco comes through soon it seems to be the least destructive to the front end - I have been talking to all three looks like it will be awhile longer for Demco and RoadMaster BlueOx has one for sale but I am hesitant to go with BlueOx with their recent issues although I have been flat towing with their equipment for years just don’t want to risk it with my new Maverick
DaveTS
New Mexico
2025 Maverick Lariat AWD 4K, 1992 MB SLK, 2014 Prius V
All (3) major baseplate manufacturers are struggling to fit the refreshed 2025 Maverick Lariat AWD Hybrid with a compatible baseplate due to Ford relocating the ACC Radar hopefully Demco comes through soon it seems to be the least destructive to the front end - I have been talking to all three looks like it will be awhile longer for Demco and RoadMaster BlueOx has one for sale but I am hesitant to go with BLueOX with their recently issues although I have been flat towing with their equipment for years just don’t want to risk it with my new Maverick
I'm eagerly awaiting a Demco solution too. They promised to call me when they have one ready.
