Bed storage mistake?
MrShadetree
Missouri
None
This didn’t work. I opened the cooler today to find water inside. My car cover and car cover storage bag were wet. I had power washed the bed a couple days ago without removing the cooler first. Needless to say the cooler is not waterproof.
Ford Maverick Bed storage mistake? IMG_0375
thev8man
Interesting 🤔.
I wonder if the pressure and new fangled high speed cacameme water lifted the lid while you were cleaning and allowed water in?
Hole?
Booyah 👊🏽 😁 👍🏽 🇺🇸
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
Did you have your cover closed?
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
Couple clarification questions:
Are you saying that the power washing is what led to water being everywhere?
If so, are you now concerned about it not drying out appropriately or that it made it into the cooler?
If power washing isn't the problem, are you saying everything doesn't seem to be waterproof in general?
Is it possible that the height of the cooler is *just barely* too tall and didn't let the gaskets on the bed cover seal properly?
But also, the physics of this just doesn't make sense to me. If it's not the power washing, I don't know how anything would drip in the vicinity of the cooler. It would drip along the edges and down the side. My brain is spinning, needless to say.
Tbone289
Are there latches on the sides of the cooler? Coolers without latches and a rubber seal aren't usually waterproof and the lid sits on top of the cooler body, rather than overlapping the body as most storage trunks do.
Just because the pressure washer forced water into the cooler doesn't mean the cooler isn't "weather proof" though. Even the hardest, blowing rain shouldn't make it's way in like direct pressure will. You may never get any water in there if you just avoid hitting it with pressurized water.
MrShadetree
MrShadetree
Missouri
None
It took me a little while to figure it out. Yes using the power washer isn’t the problem. I just have to avoid aiming the water steam at the seam between the cooler base and the lid or remove the cooler during a bed wash. I may add latches just to be safe.
And to answer @Wilklersticks the cooler sits 1 inch below the cover.
MrShadetree
MrShadetree
Missouri
None
Interesting 🤔.
Hole?
Booyah 👊🏽 😁 👍🏽 🇺🇸
I believe you are right. The pressure lifted the lid and allowed the water in. There are no holes.
MrShadetree
MrShadetree
Missouri
None
Yes. Keep the pressurized spray away from the lid.
MrShadetree
MrShadetree
Missouri
None
water got in because I didn’t use common sense. Don’t aim pressurized water at the lid of the cooler.
canuckford
Lou
toronto ontario canada
2025 2.0L ECO, 2015 Transit T250
I may add a thin gasket and latches.
When you install the latches you'll have to make holes for the screws so just inject a little silicone in the holes before putting the screws in. Or for a simple work around, bungee cord the lid nice and snug.
rk06382
Robert
Alaska
This is my setup for Costco shopping.
OEDRO Truck Bed Mat:
Two Coleman® Marine Hard Coolers.
Ford Maverick Bed storage mistake? Bed mat b w coolers 20250630_164438[1]
With soft cooler bag and BAKFlip MX4 TS closed.
Ford Maverick Bed storage mistake? Bed mat c w coolers 20250630_164728[1].JPG
After I close the tailgate everything should stay dry.
Hmmm = brain spinning = I am 82 and eat 1 or 2 Brazil nuts about 8 pm and 2 walnuts about 8 am everyday = helps recall/focus and circulation by reducing inflammation. 🤗
Ford Maverick Bed storage mistake? chrome_screenshot_Jul 1, 2025 6_54_22 AM CDT
