Bed Blanking Plate - 3D Printed for 12V Accessory Outlet
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
TedTX
Ted
San Antonio TX
Please be careful with the Amazon & eBay pigtails.
I ordered one that was advertised as specifically for the Maverick Flex-Bed
The connector fits but the wires are for speakers, very thin gauge.
This is fine if you want to use them for some LED lights but not if you want to max out the 15 Amp spec for a compressor/inflator.
Agreed, have updated my post. Ran into many issues with the non-Ford parts being too under gauged and blade way smaller than useful. Hope others reach this post before ordering.
TedTX
Ted
San Antonio TX
Due to a DIY camper build blocking those plates I will be redoing my 12v plugs into a cubby storage that I will buy with my Ford Points. if your in the Austin-San Antonio Area DM for free 3D plates. Keeping the Ford plug side.
TheWizziard
Texas-RGV
Question regarding this pigtail connector. White wire (positive) has larger terminal (fit perfectly on the positive connector of the 12 V outlet). Black one has much smaller terminal. How to connect it to the large negative contact on the outlet? Cut and replace with the larger terminal?
Also my Ginsco 12V outlet has a fuse and a wire. As I understand it would be nice to use a fuse in this potentially wet place. How to connect it between the pigtail and the outlet?
Thanks in advance
If using after market pigtails be careful using the wire color for polarity. Many of these pigtails were manufactured for speaker hook up not 12v power. It is best to plug it in and check the polarity to be sure. Also note the other recent posts about the wire size of the after market pigtails.
nunucello
nunucello
Marcello
New York
That's a good point. So far everything works. Would be nice to replace with OEM.
TheWizziard
Texas-RGV
I find it interesting that non that I have sen so far on Amazon or eBay give the wire size. Some are labeled as speaker connectors but some are advertised specifically for he Maverick Flex-Bed
TheWizziard
Texas-RGV
The blade size is an indicator of wire size. If you need a larger blade you need a larger sized wire to power the device! Order the correct size pigtail.
TheWizziard
Texas-RGV
One of the issue I found is that most of the pigtails on Amazon and eBay do not include the wire gauge (size)
Lack of proper descriptions for everything on web sites is lacking. I will request info or more often will not purchase because of no info. It may be better to buy wire and correct size spade connectors but will wind up with a multiyear/Lifetime supply. I just bought a 3 year supply of Samsung refrigerator water filters at Lowes.com because they were 25% off with a 2 pack and an additional 10% off if 2 or more 2 packs were purchased. When last of these filters die the fridge will be 15+ years old and the new ones using the iso butane coolant are much more efficient.
RedRider
Kitchener, Ontario, Canada
Nice! I ran down to the Kitchener Library and printed one for nothing. Took 30 minutes printing time and works great!
Note the spades and blades are sized to match wire gage. If you are buy pre mated to wire and you need to up size spade or blade the wire will most likely be undersized.
Decayed
yes
a car
If you don't know how to use a voltmeter, splice/crimp spade connectors, distinguish positive from negative or estimate electrical loads, please don't mess with the bed accessory wires. You can spend $28 or whatever on the OEM connector or if you know what you are doing you can get the $6 one on amazon. Your call.
desmobob
Upstate NY
2022 XLT EcoBoost tow package, 1995 Ducati 900SS SP, 2025 CF Moto CF500
I'm very surprised that an accessory manufacturer (or Ford!) doesn't offer a simple replacement plate with a 12V DC outlet that's wired to plug directly into the Ford pigtail. It would be a huge seller, right?
