Battery recall done
Is your charging system set to charge to 100% ?
Suzukiridr14
Frank
Sarasota Florida
Had the battery replaced under the recall ,new Agm even start stop works now.
There is no recall to replace the battery, it's only replaced if your dealer says it needs replacement. I still have my original 12V battery in my hybrid into my 4th year. I would love a free AGM battery, but they said I'm already out of warranty.
'22 MY EcoBoosts with the flooded battery did have a recall to replace them with an AGM.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
There is a 12v battery recall on some MY22&23 EB Mavericks.
Frenchy
Bert
Taylorsville Utah
Ford has issued a recall affecting over 272,000 Maverick pickup trucks due to issues with the 12-volt starter battery. This recall includes models from the 2022 and 2023 model years.
zach57x
FL
2022 Maverick XLT
They put a AGM in my hyrbid 2 weeks ago and I checked with Forscan it’s at 80, should I change to 100
Propane Burning Man
Will
Gold Hill, Oregon
24 Maverick Lariat, 007 Mustang GT, 2015 Propane Transit 150, 1970 VW Dune Buggy
The 12-volt hybrid battery does not start the engine. The high voltage battery uses one of the electric motors to start it. Which also means it does not even have a conventional "starter". ✌
Yeppers but wait til ten other guys chime in.
In case I’m wrong.
https://share.google/0rVBrDJIQ9MIUcWzu
Ford Maverick Battery  recall done IMG_2079
AGM, LifePO4 and lead acid have different state of charge charts.
FWIW my Motorcraft AGM that came in my 2024 Eco Lariat charges to 12.54 VDC so 94%
I’m past 10,000 miles with nothing turned off and last winter it sat two weeks un touched.
I’ve never seen any kind of low battery notice.
icegradner
The 12v battery doesn’t start the motor, but it is required to start the computers that tell the electric motor to turn over the ICE. ;)
In any case, the 12v battery recall is only for Ecoboost Mavericks, not Hybrids. No idea where this person you replied to is getting the 200k+ number from, unless they are counting the other Ford models included in the recall (Bronco Sports, Escapes etc).
MaverRick
Rick
No battery issues after 3 years with my Truck but thanks to the recall I got a new battery for free!!
Antwc
Anthony
NY
Ford maverick
I took my 22 Mav in for the battery recall. They replaced it and now the battery light came on. Never had any issue for 79,000 miles.
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
I used Forscan to make many changes to my 25MY Mav Hybrid, including 12v SOC from default 80% to 85%. Im not an expert, proposing that's the perfect level, but haven't experienced "Sleep" since this change. Serves me well, so will stay @ 85% until it doesn't.
zach57x
FL
2022 Maverick XLT
Since they put the AGM in a month ago or so have had no deep sleeps that I’m aware of. Don’t use ford pass but my interior lights have always turned on. Did not change any forscan settings.
