Battery issues = high level amp turn on.
jewc75
If you are having battery issues and have a powered sub or are using the speaker level inputs to turn on your amps you will need to run a separate remote turn on wire. Ive been chasing this issue for a few weeks and today i was able to sit in the cab and watch the amps turn on and off with the splash screen on the radio. Every time the splash screen came up the amps would turn on. Im guessing this is part of how Ford collects data and pulling the number 11 fuse did nothing for this. Give it a try if you are having the same issue.
oysterville
Oregon
2024 Maverick Lariat
Yep. I just plugged my wire into either spot 1 or 2 as they are unused. As soon as the door opens the amp turns off.
BeardedMarine
Darrin
Oklahoma
2023 Ford Maverick
I'm having batter issues right now and have searched the forums for a fix. But all the battery issues seems to be with hybrids. Hopefully this does the trick. Thanks.
