Transplant
Ryan
Nova Scotia, Canada
2016 Mazda 3
Finished my install of an upgraded sound system in my Maverick. There’s plenty of threads in here showing door panel removal and trim removal and such so I won’t go into that, but I will add that I hate all the damn clips holding everything in. I broke a few for sure, and I miss the days of just having visible screws everywhere.
My choice of upgraded gear was based mostly on getting good quality components at a budget price. I went with a component set up front and I have it powered by an amp, there’s just not enough power off the head unit to take advantage of any speaker upgrades up front. I did not upgrade the rear speakers because I can’t hear them anyway.
Scosche LOC2SL line converter with bass control. Removed this, it only lasted a year and I highly recommend not getting one of these. I ended up getting an Audiocontrol LCS2 Pro and am blown away by the improvement in sound quality. It’s not a budget device compared to other locs but it’s absolutely worth it.
Cerwin Vega XED650C 6.5” component set.
Cerwin Vega XED4004C 4 channel amplifier.
MTX TN10-4 4 ohm 10” subwoofer.
The Scosche line out converter is tucked in behind the climate controls, I tapped the front speaker signals as well as a power and ground in that area. The Scosche will send out a remote turn on signal which is handy.
RCA cables run from the line out converter up the passenger side door sill, power off the battery and the remote turn on go up the drivers side.
Amp is installed on an aluminum plate that’s bolted to an existing mount so no holes drilled, ground is picked up from an existing ground behind the back seat.
2 channels of the 4 channel amp are running on a high pass filter up the the front down the passenger side to the passive crossover. I could not get access to the inside of the rubber grommet that protects the wire bundle going into the door so I tapped into the existing speaker wires in each kick panel and tapped in to the other end of the speaker wire in each door.
Speakers are mounted to simple 1/2” mdf spacers, which are then mounted using the existing holes for the stock speakers. There’s lots of room in the doors when the spacers are used.
Tweeters are basically press fit into the existing tweeter mounts.
The subwoofer sits in a custom box that’s approximately 0.75 square feet and run on the 3rd and 4th channel of the amp bridged and with the low pass filter.
Sound wise this is a massive upgrade over stock, the frontend Is significantly louder and clearer than stock. The sub just adds another dimension to the sound that didn’t exist before. Super happy with the upgrades and I have absolutely no regrets.
Also, yes the amp is zip tied to the aluminum bracket, the tiny little bolts I bought to mount it were apparently not tiny enough, so that’s a temporary solution until I pick up some new tiny bolts.
Ford Maverick Another Budget Audio Upgrade 2CDF17E4-3719-466A-B8A2-D690D33BAB84
Ford Maverick Another Budget Audio Upgrade 7ED6CBC6-3AF7-4C7C-86CF-4BAEA1EE7443
Ford Maverick Another Budget Audio Upgrade 0210AD38-6E0B-48DB-8444-7CA3EFEF1559
Ford Maverick Another Budget Audio Upgrade 0EAF4290-0BEC-4E4C-8DB9-9204B203AE7A
Mach 1
Randy
Spicewood
2022 Maverick Lariat Hybrid sold 2024 mav hybrid 2018 F150 Lariat 3.5 ECO
Good job, any mod to OEM stereo is going to sound better, I went lower priced then you, however there's a mod that I did that would have saved you some time/energy. I am going to post my experience on the mod.
You did well.
cannon
mark
oregon
2022 Maverick XL awd
That sub doesn't rattle the living hell out of that plastic tray?
Mach 1
Randy
Spicewood
Thats a good fit on the sub..stealth...
I spent alot of time on adding mass and closed cell on that entire underseat plastic panels..
Transplant
Transplant
Ryan
Nova Scotia, Canada
2016 Mazda 3
Nope, no rattles in the plastic tray at all, I suspect the tight fit of the box helps hold things tight. But I do have a solid rattle in the passenger side door when I turn it up, I suspect I’ll be chasing a few of those issues for the next little while but I expected that.
mrjspence
Colorado
We had an FX4 Maverick that had 0 rattles even on dirt/off road. Was as well built as our older F150. We now exchanged it and have a Hybrid Maverick. Rear pass. speaker area rattling like crazy + center dash rattle + crease/gap in plastic below the hard audio buttons where the pieces join. The hybrid feels like a cheap car where the FX4 felt more “normal” idk if they assembly differently or what but it’s noticeable if you’re a rattle sensitive person like I am lol.
spydox
Eduardo
FL USA
2024 Ford Maverick Lariat
can u add photos of the tweeter installs? I'm not sure where they are or how to remove the OEMs? I was considering, but not sure if they would pop in- these SKAR 3.5" TX35
Ford Maverick Another Budget Audio Upgrade skarL1500_
Those will not fit in the dash tweeter location without extensive modification. You probably should have opened your own thread because this question is not really related unless you're al considering installing the components the OP used instead.
Speaking of the OP there is absolutely no way his box is .75 cu ft, I would say half of that if he's lucky. You can't even get .5 cuft in there if you pull the plastic insert and he left it. Subtract the woofer displacement and I'm very confident that box is significantly undersized.
