Another audio build
MikeyG
phila
Any updates?
Thagh0st
Kyle
Ft worth, TX
xlt maverick
Any updates?
Doing some testing on CLD and then slowly getting the supplies I need for for decoupling and doing a tiny bit of soundproofing.
Here is some fibermat 25 on the left and some mega zorbe on the right. I used some stuff called ciamat on my a pillars as well. Just testing a lot of stuff is all, been busy at work as well sadly
Ford Maverick Another audio build IMG_20230301_220144
Ford Maverick Another audio build IMG_20230106_200514_01
MikeyG
phila
Nice! Have you built a box yet?
Thagh0st
Kyle
Ft worth, TX
xlt maverick
No not yet, that's gonna be the last thing I build most likely, I still wanna get the 5.25 coaxials in the rear and change out my dsp to a helix or mosconi. I'm still trying to figure out what subwoofer I'm going with as well.
Alpine RS 10. Brand new... haven't even seen any reviews yet. 3.25" mounting depth, 20mm xmax.
https://www.alpine-usa.com/product/r-series-shallow-subwoofer-rsw10d2
Not aware of anything else like that on the market. JL TW10 has 10mm, Kicker L7 10" has 9mm.
It's what I'd use if I did a single 10" in a fiberglass enclosure. If I were to melt my R2 8" with 500w (rated 350, heh) I'd do it now, otherwise, I'll just have to live without. :LOL:
Thagh0st
Kyle
Ft worth, TX
xlt maverick
I've actually been thinking about that one, but the price kinda scares me for just a subwoofer if it was 400 hell yeah, but at 600 just kinda out of my price range I'm wanting to spend.
I've been between the illusion audio L10 or upgrading my audiomobile to evo 10 version, and then the sundown sd4 which I can get any of these for a good price
it is indeed painfully expensive. :(
Thagh0st
Kyle
Ft worth, TX
xlt maverick
But it's one of those things that if I run into extra money, it's definitely happening, because that thing is a one of a kind
I was scheming to put one in the swing gate of my wife's Bronco but then I realized that when she rides with me she literally complains every time the volume is above 10.
Still, the thought was valid. In a Maverick, you can shoehorn in a 10" but really high end 10s typically need more volume and more mounting depth than you can get without cutting metal.
MikeyG
phila
I saw that alpine the other day on crutchfield but $600 that’s pretty steep! You can get a JL tw1 or even the tw3 for cheaper
JL 10TW3 is somewhat comparable and it's 450 which is a lot less than 600.
Thagh0st
Kyle
Ft worth, TX
xlt maverick
It's because it's honestly a one of a kind subwoofer, with that xmax and that shallow for mounting as well as being able to take that much power. I can see why it's that expensive
Thagh0st
Kyle
Ft worth, TX
xlt maverick
Just in case anyone loves amp porn, here are some pictures of mine when upgraded.
It has upgraded Burr-Brown OP-Amps, along with upgraded Rubycon capacitors
Ford Maverick Another audio build IMG_20230311_001616
Ford Maverick Another audio build IMG_20230311_001548
Ford Maverick Another audio build IMG_20230311_001545
Ford Maverick Another audio build IMG_20230311_001543
Ford Maverick Another audio build IMG_20230311_001537
Ford Maverick Another audio build IMG_20230311_001531
Ford Maverick Another audio build IMG_20230311_001518
Ford Maverick Another audio build IMG_20230311_001506
Ford Maverick Another audio build IMG_20230311_001458
Ford Maverick Another audio build IMG_20230311_001451
Ford Maverick Another audio build IMG_20230311_001442
Ford Maverick Another audio build IMG_20230311_001437
Ford Maverick Another audio build IMG_20230311_001433
Thagh0st
Kyle
Ft worth, TX
xlt maverick
Got some 6.5" coaxials that I will be trying to test fit sometime soon in the rear, which will be very interesting if I will be able to fit, but I will be taking the mounting area off the trim and mounting them to the metal if I am able to fit them.
Also got some spare components for front just because I like to change things out and do testing, might just make them some house speakers or something.
Ford Maverick Another audio build PXL_20230405_043845961
Ford Maverick Another audio build PXL_20230405_043838342
Thagh0st
Kyle
Ft worth, TX
xlt maverick
Here are the components, better then the focal flax but not as good as the new kx3 in my opinion (my buddy thinks they are better then both) they are pretty dang heavy lol
Ford Maverick Another audio build PXL_20230405_044047613
Ford Maverick Another audio build PXL_20230405_044054538
Ford Maverick Another audio build PXL_20230405_044214436
