Aftermarket / mod rear bumper for better departure angle?
uknat
So Cal
2023 Maverick Tremor
having driven my Tremor a lot off-road I feel the departure angle is a main limitation. Rear bumper design compounds the problem I think (look at it from the side profile to see what I mean). Would love an aftermarket option if anyone knows of one.
bgn
WA
Doesn't exist yet.
uknat
So Cal
Doesn't exist yet.
thanks yeah I have not seen anything. Starting this thread in hopes people will keep us updated. thank you
fossil
ernie
ohio
anybody have a photo with the rear bumper cover removed?
Maverickman74
Shane
Maui HI
Im just wondering where is all the pictures and video of your Tremor offroading!!!!!
As for the rear bumper, obviously there isnt one out there yet and I often build my own bumpers but this is not a 30 year old vehicle. But I did notice in the TFL review that the rear bumper was scooping up dirt. So I have been thinking, once I have it of course, of skidplating and reinforcing the rear under plastics so It cant scoop and get hung up like a gall darn graboid and also support a little weight. Probably building a steel support that goes across the bottom edge that mounts to the hitch area and then has a plate that goes forward possibly to the rear suspension cradle area. I need to do some crawling around once I get it obviously.
Another optional partial solution is adding air bags. When off road pump em up and keep the rear from squating as much in certain situations. It would help a lil bit. Also adding a hitch insert that you dont mind scraping will save a lil body damage as long as the front tires get enough grip to keep you moving.
uknat
So Cal
Thanks for those ideas. Sorry I don’t have videos. I’m not an off-road or truck enthusiast I just use my truck to get from A to B with dirt in between. I can add that if you scrape the rear even lightly, the bumper cover will pop off the clips that hold it. Can be a pain to get it back on in the field.
Hot Runr Guy
West Chicago, IL
fossil
ernie
ohio
Bwicka
Lakeside,ca.
Looking at cutting rear plastic level with upper line on plastic cover and tapering down to bottom at rear of wheel.
will then be adding a rear pre-runner style sliding tube bumper under the trimmed plastic edge up to rear subframe so as to add a skid plate for the rear diff.
already have exhaust ordered for in front of tire side exit,and am putting on a gr40 suspension setup from flatout suspension .
once I finish the rear I will post some pics .
the front is going to be a little tricky.would love to do some fiberglass fenders and bedsides too.
uknat
So Cal
👌🏼 I like it. How much extra lift with the gr40?
Bwicka
Lakeside,ca.
So far only 3/4 “ in rear , and a little over 2” in front .
Getting alignment tomorrow . Got 32” big muds mounted up.
May have to go longer on springs , have to see how the ride is
Ford Maverick Aftermarket / mod rear bumper for better departure angle? IMG_2815
Ford Maverick Aftermarket / mod rear bumper for better departure angle? IMG_2812
Ford Maverick Aftermarket / mod rear bumper for better departure angle? IMG_2810
Bwicka
Lakeside,ca.
Will also be pulling rear bumper and front plastics this weekend , gotta figure out how to pull ( flare rear fenders and make some molds for front fenders ! Wanna add some stance to it and bigger openings .would like to be able to get 33x10.50 tire under it ! Will try to take pics .just got the wheel liners out all around but now dark out .
Rivers90
Ben
XLT Tremor, Miata
Sadly no aftermarket rear bumpers yet.
Maybe when more Mavericks are on the road we will see more accessories available.
