Additional USB Power Outlet wanted :
Cvinnedge
Chuck
Virginia
2025 Ford Maverick XLT AWD Hybird
I would like to know if anyone has or knows how to install additional USB Power Outlets behind or under the back seat of the Maverick? Not the center console area but actually behind or under the seat.
I store my portable jumper and tire pump under the seat and would like to be able to have the charge while driving so they are fully charged anytime I or someone else needs them.
I don't want to run long cables from the center console since those ports are for passenger use.
I know people install audio components behind the seat so there must be a way to get power there, I just don't know how and if it would be too difficult to pursue for adding a couple USB ports.
Carlitos_92
In your hybrid, the 12V battery is literally under the back seat; that's where the power is coming FROM . ;)
Cvinnedge
Cvinnedge
Chuck
Virginia
Thank you. But how do you safely connect a new USB port to it?
ianjay
Ian
Toronto, Ontario, Canada
2024 Maverick Lariat Hybrid , 2008 Ford Ranger
Amazon is your friend. Type 12V USB outlets. The one I picked has two blue USB and one USB-C oulets as well as a continuous volt readout, all packed into a round surround. Comes with connectors (you may have to crimp larger ends to attach to the battery terminals and a fuse block with two spare fuses. All you would need to do is provide a small mounting plate.
We use them on an A-Liner camper to supply 12V power inside as well as give a visual indication of the charge on the trailer's battery.
Cvinnedge
Cvinnedge
Chuck
Virginia
Thank you.
sprubs
New England
Nunya
wouldn't the options above slowly drain your 12V battery? I'd think you'd only want it charging when you are driving around.
Cvinnedge
Cvinnedge
Chuck
Virginia
Yes. I only want it to charge when driving like the other existing USB ports.
