Adding Memory seat position
Luc
Lariat First edition
*First edition, Lariat*
Hi.
Looking for a way to add a memory seat position like the escape and other have from factory. (Wife is 5,2 I am 6')
My dealer doesn't want to look into it, but i am 🤣.
Thanks for any help.
Micheal
Micheal
PNW
2012 Escape Hy, 2014 Escape, 2022 Maverick Lariat
Hi.
1. Don't let your wife drive your Mav
2. Buy your wife her own Mav
But I think I've seen somewhere on MTC that it can't be done, even with Forescan, but others know better than me about that.
Pstewone
Patrick
Punta Gorda Florida
2025 Maverick Hybrid AWD Lariat
Following.... Even the 2025 Lariat does offer this. It a pain to adjust when one driver is 5ft. and the other is 6ft. Ford missed the mark on my top trim Maverick.
Waterick
Richard
Laurens county SC
You mean: "does not offer this", I assume.
Pstewone
Patrick
Punta Gorda Florida
That's right, Ford does not offer it on the Maverick even on the top tier seats.
BlueSpec1
Gene
Just thinking what it might take to add memory seat function in a Lariat.
Besides Forscan config changes (if possible):
Power Seat Switches and Seat Track Adjuster motor and Seat Back motor rewired into a Driver Seat Module (DSM) from an Escape.
Track Adjuster Motor that has Hall Sensors to feed into DSM.
Seat Track Adjuster Motor changed from MU5Z-14547-C to MU5Z-14547-A
DSM wired into MS CAN BUS.
Door Memory switch (Momentary Contacts) to feed into Lariat existing DDM Driver Door Module.
dochawk
doc
Las Vegas
my inclination would be to disconnect from the car computer and use a microcontroller . . .
have a routine to zero by going as far as possible, and then measure travel time for there (compensating for current voltage?).
A Mark II approach would measure how far a motor has moved rather than time, and have to re-zero less often . . .
It can certainly be done mechanically or electromechanical; the 1953 Cadillac Eldorado had memory seats!
Mabcim
Rochester, NY
I looked into this before.
Need seat motors with the position sensors, so current seats can’t do it.
The simplest, is to get a seat bottom from an Escape and swap the underneath; it has the same seat track.
Then there is a wire or two that needs to be run; each sensor wire.
The control is the module in the door, so need one of those.
The next thing is the mirror. I suspect the mirror pins in the door module can just be grounded, so it always thinks the mirror is in the desired position..
mapnerd
2024 Maverick Lariat Tremor
Anyone ever figure this out?
Pstewone
Patrick
Punta Gorda Florida
I gave up on it.
