Nutty 5.0
Reading, PA
2024 Terrain Lariat
Pardon if this was posted already but didn’t see anything. Being in pinball and arcade hobbies, I have lots of different locks to try.
You can add a lock to the cubby in the bed with very little work. You will want a 7/8” cam lock. You’ll need to carefully file the hole to the edges so the cam lock fits. Thankfully you can see the marks.
A 7/8” wrench to tighten the nut to the lock, a T-20 torx to take the old lock apart, and a #2 Philips for the attaching the cam. (note I used a different style lock that used a metric 10mm nut so YMMV) Some locks may require flipping the 90 degree cam so the lock and unlock match what the door shows. I had to do it to mine. You’ll want to use the flat cam and not an offset one.
Ford Maverick Adding a bed cubby lock IMG_2418
Ford Maverick Adding a bed cubby lock IMG_2419
Ford Maverick Adding a bed cubby lock IMG_2422
Ford Maverick Adding a bed cubby lock IMG_2420
Ford Maverick Adding a bed cubby lock IMG_2421
I like the idea of locking that storage area. Specially the round key design.
Thank you
Ford Maverick Adding a bed cubby lock 20240716_070643
Nutty 5.0
Nutty 5.0
Reading, PA
2024 Terrain Lariat
I like the idea of locking that storage area. Where did you get the lock that has the round key? Like the one showing in your picture?
The Amazon ones are all flat blade.
Thank you
It’s a security lock style. I have all sorts of locks I use so had this handy. So you could likely use this:
https://a.co/d/8YYUOnl but would likely need to cut the cam down. I changed to a traditional style so I didn’t have to mess with it.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Very nice job! I added a second bed cubby on the driver's side of my XLT and love it. My cheesy approach to improved security was to fabricate aluminum replacements for the stock lock bodies on both sides. They're not at all "secure" as I just use the ignition key like a screwdriver to open them. I figured that those plastic doors are pretty easy to pry out, so actual security is impossible. My lock is mostly psychology but might slow down a lazy kid who happened to walk by.
Ford Maverick Adding a bed cubby lock Lock
Nutty 5.0
Nutty 5.0
Reading, PA
2024 Terrain Lariat
Not cheesy at all and very clean !
Jah.
Jah.
Central Florida
Now have cubby on both sides . hard tonneau for security .
Ford Maverick Adding a bed cubby lock 20220511_135810
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Ford could make $50/apiece for this idea. Been seen before, but THANK YOU for sharing! (plus the links)
millertyme15
Bobby
St. Louis
Nissan Murano, Chrysler 200, Jeep Wrangler
02Knight
Michael
2024 Ford Maverick XLT Hybrid
