EDIT: adding parts list to the original post so it's easy to find. The box dimensions are perfect *without the plastic insert*. If you want an 8" that fits inside the plastic insert check other threads. If you really want a 10" your best bet is fiberglass and you will want to watch the box volume carefully- I would put a high performance 8" against a shallow mount 10" any day. If I melt the voice coils on this sub I will buy a dual 4 ohm model to replace it, but so far it's working awesome with 500wrms at 1 ohm. I am honestly amazed by the sound quality and volume at this price point.
EDIT #2 11/29/22 ** I had to move to fuse #3. #3 and #6 are the only confirmed (at this point) switched in the cabin fuse panel. I was originally using #20 and my truck was fine a month, then started going into Deep Sleep almost immediately after the ignition was off. After switching fuses, I have only seen Deep Sleep twice and once was definitely after getting in/out of the truck a lot at a campout. **
You'll of course need a table saw, jigsaw, workbench, electrician pliers, double stick tape, spray glue, zip ties and other common tools.
(original post)
This is a work in progress, but someone asked me for dimensions so I decided to post now and update as I get it completed over the next 1-2 weeks. This is not a show truck. Let's just start with that, if you can do shop-quality work on your own you don't need this thread, and if you want a shop-quality finished product you should probably just have a shop build something custom for you.
Build components (added parts & pieces 10/11/22)
- Alpine R2-W8D2 8" sub $250
- Kicker Key 500.1 $270 (auto-gain and dsp at this price point blows my mind)
- Kicker CXARC remote bass level knob $40
- Metra Line-Out Converter and 1' RCA male-male cable $25
- Stinger dual 4/8 ga distribution with 8/10 ga output, - 1' Stinger red & black 8ga, local shop $50
- Scosche 4ga wiring kit w/60A blade fuse $25 (crazy good deal on Amazon)
- Stinger 10ga speaker wire already on hand but call it $15
- Recoil Add-on Fuse Holder 10A & 20A blades (I used 10a/10a in fuse #3) $10
- 4x8 sheet of 3/4" MDF $55 Lowes (this is enough to make 3-4 boxes at least)
- 40"x40" subwoofer carpet $15 (watch this video to install)
Honest total: $755
Quotes from shops ranged between $1800 and $3200, of course, their builds varied.
Time required: 16-20 hours (I'm a rookie, expert probably 4-6 hours)
I'm taking speaker-level input from the B&O 6x9, which I'll be disconnecting and removing. (EDIT 10/11/22 I disconnected it, but put it back because there's a big hole in the truck, see pic below.) The 6x9, bracket and plastic enclosure are considerably larger than the Kicker 500.1 so I'll be mounting the amp in that location. The amp does 150w @ 4ohm, 300w @ 2ohm, and 500w @ 1 ohm. Obviously, the sane thing to do would have been to buy the dual 4ohm sub and run it at 2ohm, but YOLO. If you don't have B&O the best way to interface is to get a harness adapter that taps into the ACM. And then you'll want a multi-channel amp but you could use another Kicker. The 200.4 and 500.1 together would be great and they're very small. If you don't have the B&O you may not realize how much depth is available at the bottom of the rear seatback. It's easily 4-5" deep.
My design goal was to not modify any metal and if I'm honest, I'm not an awesome carpenter so instead of building a trapezoid like Ken did over here I wanted to make it a very easy rectangle. There are numerous 10" woofer builds out there and if you look at them and make some of your own measurements you'll see that it's very, very tight trying to fit a 10" sub and grille even if you remove the plastic tray insert. There are a lot of high performance 8" available, I chose this one because of specs vs cost. Ideal sealed enclosure is only 0.3ft3 (gross excluding woofer volume), I'm actually slightly larger than that around .35.
There's 4 parts of the underseat inserts and you will want the outer pieces because otherwise it's very ugly and you would have a hole under the seat edge. But... do you really need the center piece? I built several cardboard mockups to find out what's workable.
With the tray (Ken's box and my mockup agrees) the bottom is only 7" wide because of the FITS inserts and the tapered trapezoid shape. If you pull the insert you can fit 10.5" wide at the bottom. In order to get it in there without cutting metal, I chose to make the box only 6.5" deep (tall). You could make it less than 10.5" wide and deeper, but I want the largest possible surface on the top side so that the woofer is not near the edge of the box. I noted that Ken's box is 16" long but due to the width of mine at the bottom (10.5 vs his 7) I shortened mine to 15".
More to come...
(original post)
Honest total: $755
More to come...
