A Weird Question
Krischievous
Kristen
Lehigh Valley, PA
2023 Ford Maverick XL AWD Iconic Silver
I am a big girl. 300lbs (trying to lose but that's beside the point) and I just have to know - what's the weight max for climbing into the bed (the pressure on the tailgate)? Please don't try to attack my size, I don't like it either. It happened before I realized it, but while I am working on it I just want to know if I can stand up there - or climb on it - without denting/bending it. Thanks....
RR - All the way
GA
I have read on this forum that it is 500 lbs. for down position and 400 for the in between position.
Might check the manual. Good luck with your weight loss if that is what you want. Hey, we can't all be perfect! In fact, NO ONE is!!!! 👍
Edit: Manual says 500 lbs for middle position; I cannot locate a weight spec for the down position.
MetalThunder
MetalThunder
Blue Water Area / Thumb Coast "Mishigami"
www.automobile-catalog.com
2024 Iconic Silver AWD XLT 4K Lux Ecoboost
400# per Ford
Tailgate Load Limits | 2022 Ford Maverick Videos | Ford Owner Support
Maverickman74
Shane
Maui HI
Me and my wife are your size. We sit on it together and tailgate all the time. I also stepped up and down on mine about a dozen times the other day putting racks on my topper.
Maverickman74
Shane
Maui HI
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
I'm a skinny little guy at 160 lbs and it made a metal crack/pop sound when I hopped on.
Since then I try not to stand at the edge of it.
Standing on the rear bumper on the other hand is no problem.
paneubert
Seattle
Well the other curveball here is that some (many?) of our tailgate cables are not the same length, so you have more (all) weight on just one when the tailgate is down with no weight on it. That is until the shorter cable stretches to the length of the other longer cable.....
hdave
Toronto, Canada
Hmm, I guess I'll try again.
Hopefully that sound was something like one of the cables popping into a better place?
fossil
ernie
ohio
interesting, not much chatter on that subject for some time now
paneubert
Seattle
Yeah, I haven't seen anyone complain in a bit. But it is still a thing. My 23 was manufactured in May and my left cable is definitely longer than the right cable. I just don't care. Haha. If I put weight on it, it evens out so that both are taut.
Krischievous
Krischievous
Kristen
Lehigh Valley, PA
Thank you! A friend of mine has one and it felt really squeaky that I was scared to. Can't wait to own my own!!
RR - All the way
GA
Your avatar makes you look like you are too young for the popping to be a knee or hip joint... At my age, that would have been my first thought!!!!! ;) :giggle:
Maverickman74
Shane
Maui HI
You're welcome. Honestly I have never sat on a tailgate that didn't squeak or creak. It's just what they do. If they don't it was probably built for non truck people that really should be driving a Mercedes, especially since they paid $90k for their powered, dampend, lighted, folding escalator, bluetoothed, with a built-in mini bar tailgate. Ford did what it needed to do, make it strong enough for me and my lady, design it to make the bed space more useful, and put a coke bottle opener on it!
I weigh 310 dressed and literally stepped one footed on the lip of it several times saturday while I was measuring fabrication and fitting my topper cross bars.
Old Ford Guy
Rod
Northeast Ohio
2024 Maverick Hybrid Lariat ; 2016 Linc Navigator
good thought there, i would imagine that no 2 cables would be the precise exact length. but.... i have a hard time believing Ford's cable length tolerances for the tailgate cables are so loose as to cause issues with the the tailgate being severely out of level or failing to hold at least the 'test weight' design spec, engineers almost always 'over spec' this kind of stuff beyond what they are willing to officially certify it for in my experience working for Ford.
you may have heard of a concept called C.Y.A. (cover YOUR ass) right? if they need a 400b capable cable most engineers will design one that exceeds that minimum for damn sure.
no, im not an engineer but this is how theses things work.
to the OP my advice would be to not worry about the tailgate holding up unless there's some obvious sign of sagging or unusual noises when putting her weight on it. if that happens have a dealer or someone who knows what their doing check it out. her current weight & more should be no problem for the tailgate support system as long as there are no weird cable length issues or a loose/failing cable connector either on the bed or the tailgate.
Old Ford Guy
Rod
Northeast Ohio
glad you got ur Mav, hope youre having as much fun with yours as i am with mine :) dont sweat the tail gate thing. take a look at my other post in this thread for more.
