Sgt.Gator
Gator
Bend Oregon
2025 Maverick Lobo, 2020 Edge ST
The intent of this thread is to document my track and autox days in the 2025 Lobo.
I took my Ford Maverick Lobo to Oregon Raceway Park (ORP) for it's first track day. The truck is 99% as delivered OEM. The only mod is a Ford Performance cat back exhaust. Even the suspension settings are as delivered. Now I have a baseline to measure future mods against.
ORP is a 2.3 mile track with 16 turns and lots of elevation changes. On Camber, Off Camber, Short Straights makes for lots of cornering conditions. Two linked turns called the Half Pipe are notorious for making driving instructors riding with students motion sick! On top of that it is designed to be run both CW and CCW which makes it really 2 different tracks. I’ve been wheel to wheel racing there many times, am a member of the ORP Club, and an ORP instructor.
It was damp or raining the first three sessions. That was fine with me. I like racing in the rain, most of my most memorable races across the Pacific NW have occurred in the rain. It made for good conditions to learn the handling of the truck and the various drive modes. I used Sport mode and Lobo mode, automatic shifting and paddle shifting.
Here’s one lap in the afternoon after it dried off:
Edit 9/26/25 adding data:
Max G Cornering: 0.96
Max G Braking: -0.95
Max Speed: 98.2mph
Fastest Lap 2:16
The G Forces were surprisingly higher than I expected.
This data came off my Garmin Catalyst.
Thoughts:
It was a fun day! After reading other posts in this forum, I knew what to expect and my day went as anticipated.
Driving: Not surprising that the best mode was Lobo mode with ESC off, (thanks DMS). I’m used to racing an AWD front heavy car, a Subaru STI. Like the Lobo, the STI is way too front heavy/rear light. The best lap times in the STI come with late apexing. Like the STI if you try to max your speed through the apex you will almost certainly understeer terribly to the track out. But unlike the STI the Lobo has the Electronic Dual Clutch Rear Diff. That took some getting used to! I found that post apex, as the understeer set in with light throttle, I had to make a leap of faith and give it more throttle. Slower into the apex, then faster out. My mind was telling me I was going to power understeer right off the track. You can feel/see the understeer coming out of the apex and are sure you are going off. But once I got the power up the torque would apply to the outside rear tire and the front would magically stop understeering and turn the truck. I equate it to the first time I drove a very high downforce race car, you have to believe that going faster will make more downforce which will give you the grip to stay on the track.
I practiced this rear torque steer on the sharpest three 90-degree corners where even if it didn’t work I’d probably leave the track at 35-45 mph.
Tires: As reported by others, on the one hand they are awful. Particularly under threshold braking, grip was quite low. On the other hand, they had so little grip that I never did get my brakes to go soft. They will be fine for another fall season session, but next spring I will be upgrading.
Brakes: The OEM pads did better than I expected. They never went soft on me because the tires couldn’t generate enough grip to overheat them. At least not on a cool wet day.
I put caliper temp sensor stickers on a week before and did some spirited mountain road driving. The temp sensors never registered enough heat to change color:
Ford Maverick Sgt. Gator 2025 Maverick Lobo Track & Autocross Thread Lobo Temp Sticker 1
At the end of the track day here’s what they read, a max high of between 275 F and 300 F. When considering these temps remember this is on the outside of the caliper between the two pistons. The brake fluid inside the pistons will be much hotter. But it’s good to have the baseline for future brake comparisons.
Ford Maverick Sgt. Gator 2025 Maverick Lobo Track & Autocross Thread Lobo Temp Sticker 2 Driver
Ford Maverick Sgt. Gator 2025 Maverick Lobo Track & Autocross Thread Lobo Temp Sticker 2 Passenger
Transmission: I found the paddle shifters to be direct and easy to operate. They shift far more directly than the paddle shifters in our Edge ST. Both up and downshifts worked fine.
Seats: I used the seatbelt inertia lock and power seat adjuster to get nice and tight. I reversed the headrest to give me more helmet room; that’s a good tip! For now, I’ll live with the seats and seat belt. It’s too bad Ford doesn’t put the same belt retractor on the driver’s side as the passenger side so we can lock ourselves in more tightly. Corvettes have had that feature for 20+ years. I wonder if it’s possible to put a passenger side retractor on the driver side?
Driving with the window down: Some HPDE events require the driver’s window to be down for giving a point-by. That created a LOT of wind buffeting at 65+ mph. I found that if I opened the rear window slider it almost entirely mitigated the buffeting.
No overheating issues. When the track day was over everything still worked, an unusual occurrence in my track day experiences!
Conclusion: A fun day at the track. I’m looking forward to 200TW tires, EBC Bluestuff pads, and probably front camber bolts. Those will have to wait till next spring though. I live in the mountains and winter is coming soon. ORP only has one track days weekend left this year. But maybe I'll do wheels/tires for that last session!
Chops
Lobo
Thoughts:
What a wonderful post!
I will live vicariously through your future stories as I drive much more carefully than you up/down my local mountain 2 lane with guardrails. Thanks!
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Wow..
Thank You for the POV over a Maverick hood...
After viewing the 24hrs of "Le Mans" the last two years..
I have come to enjoy viewing road course racing from the "In-Car".. :cool:
Jerry
Cherokee
Wow..
Jerry
At’s about as close as I’ll ever get to the real deal.
The dash cam Rocks !
Looking forward to your suspension mods that will surely be coming.
Sgt.Gator
Sgt.Gator
Gator
Bend Oregon
Thanks for all the Kudos!
I've edited the first post with the actual data so we can compare the future mods. Here's what I added:
Max Speed: 98.2mph
Fastest Lap 2:16
Something I should have emphasized in the first post:
Your Lobo is ready to hit the track as delivered!
You don't have to buy tires, track pads, camber bolts, camber plates, lowering springs, racing brake fluid to go to the track......those mods are great and I will be doing some of them. But if you are a track enthusiast newbie, take your oem Lobo and go! The truck is meant to be driven at autox and track days, use it. You'll have a huge grin on your face all day. As delivered the engineers have made a balanced performance package. The tires won't overwhelm the brakes, the brakes won't boil the brake fluid, the truck won't roll over going around a corner (despite SCCA worrywarts that it will).
To find HPDE track events in your area go to Motorsports Reg, https://www.motorsportreg.com/. Some track events will not be open to newbies, but most will have sessions for newbies. They will assign you an instructor. And just because it may say Porsche Club or Audi Club doesn't mean you can't take your Lobo. They usually allow non brand vehicles because it's expensive to rent a track and they are happy to have participants. If you want to know more feel free to PM me on this forum with your email address.
NIKwithoutaC
Nik
Indiana
1986 Mustang, 2026 Maverick Lobo Sport
This is another great thread for those of us who are Lobo-curious. Thanks for sharing!
r0tax
CO
2025 Lobo 402A VB
Good stuff, and vid.
I was expecting Tight, and Slow AX footage...seeing and hearing the Lobo on a real track (above 95mph!) is cool.
The induction noise at WOT at full spool sounds so good in this thing. :D
Buggy Man
Summerfield Fl
2025 Maverick Lobo, Meyers Manx clone dune buggy
Hey Sarg,
Thanks for posting your track day experience. Looking forward to your handling improvements and results.
And thanks for posting the "Motorsportreg" web address.
Chops
Lobo
All our Maverick EB’s can suck air at 300-350 cfm at WOT. That is more suck than the strongest high end shop vac! Another reason to check the air filter regularly:)
Sgt.Gator
Sgt.Gator
Gator
Bend Oregon
I got the following comment on my YouTube Video:
"@HarleyRider503: Talk about stupid. Just seen this on Mavericktruckclub. This is video game footage..."
o_O
My first reaction was <expletive deleted>. Then I calmed down and laughed about it.
My Reply: "LOL, thanks for the compliment! It's great that you think my driving is that smooth and practiced. But for everyone else, no, it's not video game footage. Check out my channel for racing videos. "
And see: Winning Endurance Races in a Subaru
I've built a decent reputation in the Subaru and Factory Five 818 communities that I would not jeopardize.
I assure everyone in this community I'm not posting video game footage and I know a little a little bit about the subject!
r0tax
CO
2025 Lobo 402A VB
Man, show me the video game that I can drive a Lobo in! :D
The only thing I'd like to see on your HUD is Tach and gear. Come on, that video game sucks until they add in that feature. ;)
Maybe Brake and Throttle application too, but Ill let that slide for now.
Since I know the Lobo, I can tell when throttle is 100%!
Edit: Out of Curiousity, what was the car in front of you?
r0tax
CO
2025 Lobo 402A VB
It looks like a Lotus, either an Elise or an Exige
Both really light cars, but not a whole lot of power.
I bet the corner speeds are A lot higher [than the Mav] though.
And a lot less aero drag above ~50 mph.
And manual trans can keep it in the power band more consistently.
Sgt.Gator
Sgt.Gator
Gator
Bend Oregon
I'm 95% sure it's a Lotus. Next time I'll get some paddock shots.
Carlitos_92
I'm 110% sure it's a Lotus; you can practically read the "L O T U S" on the back. 😀
I think @Maverick123 called it, and it is probably an Exige. Not sure what year/trim - Lotus is infamous for repurposing the same platform for "a while." Hell, even the current Emira is basically an Evora with a body kit and a nice new interior.
Enjoying the Lobo track day stories. Cheers.
