SiLence
Subaru Crosstrek
See my previous post for Rack + Rail, https://www.mavericktruckclub.com/forum/threads/med-profile-rack-with-elevate-ts-rails.4777/
Got my Truxedo Sentry CT hard roll-up cover last night (800$ + tax thanks to this thread, https://www.mavericktruckclub.com/forum/threads/anybody-order-off-bakflip-com.5023/)
Spent ~2 hour to install the cover and adjust the racks.
Works as intended, only imperfection it that the cover rubs with the tower of the rack (the one closer to the front of the truck), but it can be pushed through.
I end up having a lot of extra seals, and made myself some sort of weather seal at the tailgate.
I will be happy to answer any questions you may have in this setup.
Ford Maverick Mid-profile Rack with Elevate TS Rail with Truxedo Hard Roll-Up Bed Cover PXL_20211209_184822493
Ford Maverick Mid-profile Rack with Elevate TS Rail with Truxedo Hard Roll-Up Bed Cover PXL_20211209_184621060
Ford Maverick Mid-profile Rack with Elevate TS Rail with Truxedo Hard Roll-Up Bed Cover PXL_20211209_184307008
Ford Maverick Mid-profile Rack with Elevate TS Rail with Truxedo Hard Roll-Up Bed Cover PXL_20211209_184838199
Jroehrer10
Jesse
PA
Ford Fusion
This doesn't look like the hard rollup on the ford accessories site, but I assume it will install the same. Looks awesome man! Appreciate you being the test dummy.
Jroehrer10
Jesse
PA
Ford Fusion
Do you know how the elevate rails were installed? drilled into the bedrails?
SiLence
SiLence
Subaru Crosstrek
No, it is clamped on, sandwiched between the bed and the rail of the cover,
Ford Maverick Mid-profile Rack with Elevate TS Rail with Truxedo Hard Roll-Up Bed Cover 1639081870697
pxpaulx
Minnesota
It isn't. It the the Truxedo Sentry CT. Loving mine, and it can be had for around $800 as the OP mentioned (see the linked thread he also mentioned). A great alternative to the Ford/BAK hard roll-up, and it is available now (unlike the BAK version).
Fleshman03
Georgia
2022 Maverick XLT
I’ll bite. Where can I find this for around $800 at a place it’s available? I’ve been looking for a hard cover that doesn’t cost $1000+.
SiLence
SiLence
Subaru Crosstrek
JASmith
Jessica
Dodge Ram 1500
Nice! I think the only thing I would do on mine is to cut the bolts down in length so there isn't quite as much thread sticking up and paint them black. The horizontal rails I would probably but in length so that they end right at the end of the vertical supports, that way they don't stick into the windstream.
Montykeel
Monty
Rogers AR
2011Escape Hybrid and 2022 XL Poverty Edition
Does that rack come with the nuts for the T Slot?
SiLence
SiLence
Subaru Crosstrek
The rack comes with a set of nuts and bolts that doesn't work with the TS rail. I ended up using the t-bolt from the TS rail tie down anchors (which comes with the TS rail), and nuts from home depot.
Yar
South Carolina
2022 Maverick Hybrid XLT Lux - VB
Thanks for posting this info. I ordered the Sentry CT from Realtruck.com based on your recommendation and they gave me the "Forum Discount" of $200. So, they charged $799 + tax versus the $999 on the Truxedo site and their own site. Sweet deal. Also, I can get the $100 Rebate that Truxedo has running right now. So that all comes to about $750 including tax less rebate. Merry Christmas to me!
NOW... if only I can get a Production Date out of Ford, I'd be a really happy camper!!!
Thanks again!!!!!!!!!
Mabcim
Rochester, NY
Rebate? Didn’t see that , after doing a quick search on TruXedo’s website.
Hot Runr Guy
West Chicago, IL
Is the bottom of this plate flat, could the bolt holes be elongated maybe 1/4"-3/8" inward to allow the stanchion to move further outward, and provide clearance for the roll-up?
HRG
Fleshman03
Georgia
2022 Maverick XLT
Mabcim
Rochester, NY
