4k tow package trailer lights not working
Jeff klein
Gulfport Florida
2023 Maverick
MY trailer lights don't work. Took it to Autonation St. Pete and they said there was nothing wrong and that their simulator says everything is working.
Has anybody been able to get theirs fixed? Has Ford responded to any complaints? How about a lemon law lawsuit?
fossil
ernie
ohio
could you be a bit more specific?
running, turns, brakes, trailer works with another truck
TheF0nz
NJ
1990 Mazda Miata
Grew up selling boats and boat trailers and this is a very common problem across the board. I've seen new boat trailers with issues and new trucks quite a bit. The first thing I would check is that it is indeed your truck and not the trailer. Grab a test light and hook it to a frame ground (I usually sneak it on the plug blade to make sure its not a bad ground if nothing happens) and test the 7 pin systematically for check each item (need a partner for brakes).
Basically what this guy shows-
If the harness checks out then it's time to troubleshoot the trailer. If it doesn't then take it back and show them your new test light skills and get the warranty job done right.
Rod
Rod
Indiana
The problem is the truck! Ford left off the wiring harness (minor detail).
Enter vin on fords recall site there is a tsb for a wire left out of some harnesses with 4k tow pkg.
catshreds
Roland
2023 XLT AWD
Lemon Law Lawsuit ??? WOW!
shadowthrone
us
23 Maverick
Not sure if a troll or "special"... considering there is an open recall for trailer wiring and googling "ford maverick trailer lights" gets you the recall as one of the first results...
Hot Runr Guy
West Chicago, IL
Not sure, but he's been on the site this afternoon without responding,,,,
HRG
Jeff klein
Gulfport Florida
2023 Maverick
I took it to the ford dealer, and they said the harness was there and not missing, but there is no voltage present on the running light pin. The only thing that works are the turn signals and the brake light-which are the same wires. Running lights, electric brake signal and probably the backup lights are not there? Yes, Ford needs to fix this. Paid for the towing package-not just during day light. The dealer says if they can't find the fix they will use another trucks harness and plug.
Hot Runr Guy
West Chicago, IL
Your dealer should run your VIN #, and they'll discover the # 23C04 recall.
Or, enter your VIN # on the Ford recall site, and see for yourself. https://www.ford.com/support/recalls/
HRG
wb5oxq
Waco Texas
2023 Maverick Lariat in Alto Blue
I had a recall notice for that I think and took my Mav to a dealer for the repairs even though I never tow a trailer my truck has the 4 k tow package.
Hot Runr Guy
West Chicago, IL
Picked up my new 2025 hybrid AWD 4k tow package maverick in January and the trailer running lights don't work. Turn and brake lights work. Had to tow a trailer from PHX to CA and discovered them not working and had to run the emergency flashers while it was dark out. After thinking the prob was my trailer I finally bought a vehicle trailer connector light tester .
After reading this thread I'm PISSED the dealer sold me a new truck with a tow package without the lights working😡 tomorrow morning they are going to get a not so nice visit from me.
You checked under-hood fuse #37, right?
HRG
