25 Lobo Start/Stop Eliminator Install Thwarted?
Luminvent
Luminvent
2025 Ford Maverick Lobo
I had zero issue disabling start/stop on my 2024 via Forscan.
And you can easily back up your factory settings and re-flash them whenever.
I'll probably try that. The truck's been at the dealership for a couple days now. Still waiting for info.
Luminvent
Luminvent
Now if only it would remember Sport mode...
F150 2.7 TT user
Kenneth
SE WI
2017 F150 XL 2.7, 2016 Edge Sport
I am assuming the Maverick has Battery-Management-System, that will be dis-abled using Forscan, dis-connecting the trailer brake system, or dis-connecting the BMS itself from the battery. Lot of folks will say this does not effect anything, but the wrong state of charge can begin can-bus issues with a bunch of mysterious system faults. A flash programer or a wired in system configuration modification do no affect the BMS.
https://www.autostopeliminator.com/...GiQRS7lVmFWJYf25p3pOm2YCk3QNO7LRoCjScQAvD_BwE
bluelobo26
Nick
San Francisco
2026 Ford Maverick Lobo
The only downside is that if you disable it in Forscan, it's then turned off no matter what unless/until you re-enable it in Forscan. I like the module because it remembers the last setting - there are some rare occasions when I do still want it to shut off while stopped.
Tbone289
As someone who has logged a lot of OBD-II data on multiple Fords including SOC, I can assure you that neither do auto start/stop BCM settings configured in FORScan, nor do they cause system faults. The BMS configuration in the BCM is completely independent from auto start/stop configuration.
F150 2.7 TT user
Kenneth
SE WI
The Forscan specific line is, BMS/Auto Start Stop, enable or disable, on the F150. Might be different due to model year or specific vehicle.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Got the truck back. Apparently the eliminator blew a fuse. I'm apprehensive about attempting to reinstall it.
I don't think I would plug it in again either. My muscle memory rotate shifter, release parking brake, push ASS off button. Forgot the button last weekend while on a trip and my GF said, "You forgot 1"
