25 Lobo Start/Stop Eliminator Install Thwarted?
gjallen3
Jerry
Arizona
2024 Maverick XLT
I have a 24 XLT. I guess I can count myself amongst the fortunate as it seems Ford has in fact made it more difficult for 25+ model years to install the eliminator. It was not difficult at all. I didn’t even have to take the console apart or remove it. The switch that has the start stop switch, drive mode, brake hold, and traction control buttons, came out with a little effort by sliding a credit card on each side of the switch and the console housing disengaging the tabs. Then using a plastic pry tool to pop it out, disconnect the harness from the bottom of the switch, plug in the eliminator, then the harness back in. Snap the switch back in the console. I recognize that 25+my are designed and configured differently, and apologize for rubbing salt in your wound, but this may help those with 24 and earlier years.
havoc
Jeremy
Providence, RI
Lobo
That plugging that Chinese designed PCB and workmanship into my factory harness scares me more than using Forscan to disable auto start/stop on the module itself. There’s no way they plug these into a test fixture to QC checks.
gjallen3
Jerry
Arizona
2024 Maverick XLT
Are you OK plugging in Chinese manufactured accessories into the USB ports? Dash Cams,, wireless dongles, LED lighting kits directly into harnesses? I could list several more examples but the point is I think there is an inherent risk when plugging in anything electronic related, or any electrical modification on these vehicles today.
gjallen3
Jerry
Arizona
2024 Maverick XLT
The trailer plugs are another example. I read of lots of things being plugged into them. The eliminator simply records and saves the last position.
Aleks
Aleks
West Coast
2025 Maverick AWD Hybrid - Lariat
Thats a little pedantic.. theres a difference between 12v power or a wireless usb carplay dongle vs a vehicle specific connector to alter the behavior of vehicle functions.
I would view one as an inherent risk higher than the other, absolutely. For example one of them is now covered with a security rivet blocking access, vs a usb port or tapping into 12v for dashcam power.
I'm also curious what the dealer will say, hopefully its a relatively simple thing to get the truck back in action.
Tbone289
MO
Why do you believe it's an impossibility that they QC test the units?
Tbone289
MO
And who exactly wrote the Forscan program? Oh right. Russians. That's comforting.
I'm not sure how that relates to my question, which was why user havoc felt that there's no way that the Chinese manufacturer does QC on their eliminator product.
I didn't say a damn thing about FORScan. In reply to your comment; I'm not "comforted" by either one, but they both seem to have a good track record. I've been using FORScan for 14 years with no issues, and I haven't seen many examples of the start/stop eliminator not working.
F150 2.7 TT user
Kenneth
SE WI
2017 F150 XL 2.7, 2016 Edge Sport
You do know most all the electronics come from Asia, or do you?
ShadowBlack XL440
Robert
Northern Ohio
Gullzway
OK
1968 Ford Mustang Fastback
I have that this plug will disable the BLIS system.​
I tried a hitch brake light to help keep my Hybrid 12v charged, before replacing with an AGM BAttery.
As soon as I saw it disabled BLIS/rear Cross Traffic alerts, I removed and returned it.
edmc
Ted
Ohio
2026 Ford Maverick Lariat, 2020 Subaru WRX STI
I had zero issue disabling start/stop on my 2024 via Forscan.
And you can easily back up your factory settings and re-flash them whenever.
