2025 XLT remote start with Cheap replacement key fob
Cancunbadlands
Cancun
Cancun
I believe 319MHZ is for flip keys & 433MHZ is for keyless in 2024
There is a white sticker on your key when you got it & frequency is printed on it
I'll check later tonight and a let you know to make sure
Cancunbadlands
Cancun
Cancun
It says 315MHZ
It's a Lariat Tremor, no start button, with keyless easy entry so... what you say?
Ford Maverick 2025 XLT remote start with Cheap replacement key fob 20250821_194222
Ford Maverick 2025 XLT remote start with Cheap replacement key fob 20250821_194200
Cancunbadlands
Cancun
Cancun
Larry the lariat
Roli
Miami
Mazda B3000
To program a new key without FDRS you need 2 keys already programed to the vehicle.
Remove the liner in the bottom of the center console.
You will see a indentation slot to place a key in there, its the back up slot in case the battery goes dead in the fob
Keep Foot OFF the brakes for entire procedure
Place the first programed key in the slot & press the start button
Wait 10 seconds & press start button again turning it off.
Within 10 seconds place second key in slot & press start button
Within 10 seconds place the unprogrammed key in the slot & press start button
You should see a message on the instrument cluster "Key Programing Successful" & the door locks will cycle
Does this mean that I will have 3 programmed keys? Or does the Ali express key take position #2 and the other Ford key becomes obsolete?
Also, thank you for all this information!
Quest
Quest
yes you would have 3 programed keys
Quest
Quest
Larry the lariat
Roli
Miami
Mazda B3000
I purchased the key you linked to. I'm really hoping the remote start works. I purchased the remote start x OBII plug in and that works fine but I really like the look of the "2x" key. As long as it starts my car and other basic functions, I'll be happy.
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
My 2025 Lariat hybrid with key-fob remote start is 434mhz
The key code is printed on the sticker on the BCM (near the passenger floor fuse panel) perhaps the frequency is on that sticker as well?).
Quest
Quest
The only place they show key frequency is the sticker on the key or the dealer access section of HvBOM /features
Ask your dealer service advisor or parts dept, it's always the first of the 2 possibilities
Second # is TPMS
Ford Maverick 2025 XLT remote start with Cheap replacement key fob Features
Larry the lariat
Roli
Miami
Mazda B3000
I have a 2023 Lariat EB. I'm hoping I'm on the 434MHz. Let's see what happens when I receive the key
Quest
Quest
You need to check what frequency your on before ordering anything
Cancunbadlands
Cancun
Cancun
I'll double check
Cancunbadlands
Cancun
Cancun
Don't you have a key fob with a sticker on the back?!
