2025 Maverick Hybrid Dinghy Harness
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
I cannot seem to find a dinghy tow harness for my 2025 Maverick. For those with the Hybrid Maverick what did you use to make your rear lights run off of the charge cord coming from the RV/Motorhome? Any pics would be greatly appreciated.
robo44
Ed
San Jose, CA
2024 Ford Maverick Lariat
On my 2024, i use Demco products (purchased via eTrailer) comes with the cable that is connected to the coach via 7pin - 6 way
DM9523010-54Demco 4-Diode Universal Tail Light Wiring Kit for Towed Vehicles - 7-Way to 6-Way Adapter Cord
fastgascar
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
Sounds like the only option is to cut the OEM harness and use a universal dinghy kit.
Dave O
New Smyrna Beach Florida
I purchased the complete flat tow system from RoadMaster and just return from a 400 mile trip flat towing my 2025 Maverick Lariat AWD Hybrid everything worked perfect
RoadMaster
Base Plate
Nighthawk Tow Bar
Electrical Kit includes the light harness
Charge Wire
Towing Accessory Kit
Ford Maverick 2025 Maverick Hybrid Dinghy Harness IMG_5049
Ford Maverick 2025 Maverick Hybrid Dinghy Harness IMG_5044
Ford Maverick 2025 Maverick Hybrid Dinghy Harness IMG_5270
Ford Maverick 2025 Maverick Hybrid Dinghy Harness IMG_5257
Ford Maverick 2025 Maverick Hybrid Dinghy Harness IMG_5255
fastgascar
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
RoadMaster
Base Plate
Nighthawk Tow Bar
Charge Wire
I just purchased the Roadmaster Baseplate, I am considering the night hawk tow bar to upgrade my current blue ox tow bar, really just for the lights so I am still on the fence about that one, I use the RVI Brake 3 for the aux brake as well as there tire monitoring system and battery charger. My only issue is cutting the OE harness for the tailight, so I am currently ISO the trailer wiring harness for the 2025 Mav, the 2022-2024 Mav has a different plug. I am going to try the one for a 2022-2024 Ford Bronco. Did you install all the parts on your Mav yourself?
Dave O
I’m very happy with the RoadMaster gear it pulled great and no issues- I had a local company do the install they have a very good reputation and a great family owned business
The Nighthawk is a great tow bar I initially purchased it to replace my BlueOx Tow Bar which I still use on my 2004 Jeep Wrangle TJ but decided to go with RoadMaster on the 2025 Mav - I really do like the LED light bars on the Nighthawk and the integrated cord and safety chains it’s definitely an upgrade
fastgascar
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
Does anyone know if the taillights need a separate ground circuit to each one, coming from the tow car
fastgascar
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
Toad harness is done, no need to butcher a factory harness, to splice in diodes
Ford Maverick 2025 Maverick Hybrid Dinghy Harness Mavericktoadharness
Randelsclan
Scott
Ocala FL
2025 Lariat Hybrid
is that toad harness the one from Roadmaster?
fastgascar
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
No sir that was a custom one I made. I did not want to cut the OE connectors. It’s a Hopkins universal kit with Ford OE connectors
Bill Aggie
NC
Ford Maverick Hybrid
I used a set of wireless magnetic stick on lights. I added a 12 volt line from the motorhome to the 12 volt DC battery to keep it charged up. The 12 volt system is required to keep the truck in the four down tow mode.
Jsmith101
Jonathan
Temecula, CA
2025 Ford Maverick - Lariat
Love this set up and want to do the same! Can you share the PN’s for those connectors?
fastgascar
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
Hopkins Towing Solutions 55999 Universal Towed Vehicle Wiring Kit, Isolates Towed Vehicle from Motorhome
and
56468 4 Pin Trailer Wiring Harness for 2021-2024 Ford Bronco with LED Taillights, Vehicle-Side Flat Tow Hitch Wiring for Powering Trailer Taillights(*Note: The connectors for the 22-24 Maverick's are not the same as the 25 the guide pin is not in the correct location**)
Jsmith101
Jonathan
Temecula, CA
Thank you and good to know on the ye
R/model difference. Appreciate the quick reply!
